can i undo diskpart clean command and do i need to close the data recovery software im running right now if not its not working then cmd then open disk management initalize disk assign letter
2021-04-19T10:19:11+00:00
can i undo diskpart clean command and do i need to close the data recovery software im running right now if not its not working then do it in usb repair your computer cmd boot manager or just type in cmd then open disk management initalize disk assign letter
    2021-04-20T18:00:47+00:00
    can you suggest,recommend what software i should do first
  2. DaveM121 930.3K Reputation points Independent Advisor
    2021-04-20T18:04:30+00:00
    Hi sanyijani
    Not really, search the Internet for 'Free Utility to recover partition after Diskpart Clean Operation' . . .
    2021-04-20T18:17:05+00:00
    hetman partition recovery is good then i recover my files then create a new volume and convert mbr to gpt?
  4. DaveM121 930.3K Reputation points Independent Advisor
    2021-04-20T18:20:01+00:00
    Why are you trying to convert the disk to GPT?
    2021-04-20T18:20:40+00:00
    before the diskpart clean command it was gpt disk not mbr
