can i do recovering it like before it was trojans or undo that diskpart clean command easeus i tried it but not so much files and folders i didnt not like it i need partition or disk before it was trojans or undo that diskpart clean
can i undo diskpart clean command and do i need to close the data recovery software im running right now if not its not working then cmd then open disk management initalize disk assign letter
can i undo diskpart clean command and do i need to close the data recovery software im running right now if not its not working then do it in usb repair your computer cmd boot manager or just type in cmd then open disk management initalize disk assign letter
2021-04-22T19:42:17+00:00 -
2021-04-22T19:47:30+00:00 i hope i didnt full format it the partition then all my sectors are lost or no? i didnt dont do it with volume wizard just formatted it then idk if i uncheck or checked quick format if it was full its instantly or disk management not responding if it was full i dont know
DaveM121 930.3K Reputation points Independent Advisor2021-04-22T20:18:22+00:00 Hi sanyijani
Please try EaseUS Data Recovery, and see if that can find your files
2021-04-23T06:26:34+00:00 I can find the files but u said i overwrite the files if i recover on same drive and c has only 450gb and d has 1tb disk space
