can i undo diskpart clean command and do i need to close the data recovery software im running right now if not its not working then cmd then open disk management initalize disk assign letter
2021-04-19T10:19:11+00:00
can i undo diskpart clean command and do i need to close the data recovery software im running right now if not its not working then do it in usb repair your computer cmd boot manager or just type in cmd then open disk management initalize disk assign letter
    2021-04-21T16:42:45+00:00
    Ps you wont be able to recover the previous operating system and your thirdy party software very extremely rare after diskpart command clean to do its not like Fdisk.
    Chance are very slime to recovery from such clean wipe without a back up of the harddrive its means fresh install and hours of setting up all your software again.
    2021-04-21T16:57:34+00:00
    can i check if i quick formatted the drive or full formatted it is there anyway to see it?
    2021-04-21T17:09:30+00:00
    i scan the local disk D: now and it says 5 hours left to find 1tb of files wish me luck
  4. DaveM121 930.8K Reputation points Independent Advisor
    2021-04-21T17:10:31+00:00
    Hi sanyijani
    The very best of luck, I do hope you can get your files back ...
    2021-04-22T11:59:23+00:00
     here it is
