can i undo diskpart clean command and do i need to close the data recovery software im running right now if not its not working then cmd then open disk management initalize disk assign letter
2021-04-19T10:19:11+00:00
can i undo diskpart clean command and do i need to close the data recovery software im running right now if not its not working then do it in usb repair your computer cmd boot manager or just type in cmd then open disk management initalize disk assign letter
    2021-04-21T13:07:02+00:00
    if i delete the volume then its formatting the volume  to ntfs then i lose my data ?
  2. DaveM121 930.8K Reputation points Independent Advisor
    2021-04-21T13:27:14+00:00
    Hi sanyijani
    No, that is only changing the partition type, you will still be able to recover your files, if they are recoverable
    2021-04-21T13:30:58+00:00
    should i quick format the drive and to change to ntfs or delete the volume and make it ntfs with volume wizard its formatting that too or no?
  4. DaveM121 930.8K Reputation points Independent Advisor
    2021-04-21T13:33:30+00:00
    Hi sanyijani
    Once again, please do not format that drive, that will make file recovery harder just follow the steps I provided and do nothing else
    Right click that RAW partition and select Delete Volume
    Then right click the resulting unallocated space and choose New - Simple Volume and do not make any changes just accept the defaults
    2021-04-21T13:34:54+00:00
    i accepted it before with defaults and its raw i dont know why its not ntfs because trojan changed it i think
