Hi sanyijani
Do not format that drive, just create a new volume on it in Disk Management, as I have explained to you previously
can i undo diskpart clean command and do i need to close the data recovery software im running right now if not its not working then do it in usb repair your computer cmd boot manager or just type in cmd then open disk management initalize disk assign letter
Hi sanyijani
if i create a new volume can i still recover my files back
Hi sanyijani
Yes, that process will not stop you recovering your files, it just creates a new volume on the drive
should i just use testdisk to repair the partition table ,partition structure because clean command deletes that
Diskpart's clean command wipes out the MBR what is this means ? all my partition is lost or just the gpt disk i was using with windows 10 when it was windows 7 i was using mbr or gpt i dont know 2yrs ago
