APC INDEX MISMATCH BSOD error Today reported for more that 10 Dell desktops - Failed win32kfull.sys
2021-03-10T08:39:05+00:00
Hi Team,
Getting BSOD on more that 10 Desktops, Some reported while printing from PDF , Some during working on Excel , Some reported opening AutoCad
its random reporting , Checked the Dump and it shows  win32kfull.sys Fault not much .
any of you guys have faced similar or fixed .
2021-03-10T09:27:09+00:00
Hi Toji,
Apart from Dave's response, did you Patch your PC yesterday?
I have some reports wrt Printing triggering a BSOD with the same code since yesterday.
Edit 12/03/2021
Microsoft has said that this is a known issue and is being investigated.
In the meantime, uninstall the update.
In the search, type cmd, right-click it and choose Run as administrator.
Paste the command given below:
wusa /uninstall /kb:5000802
Press yes and afterward pause the updates for 7 days.
(Replace 5000802 with 808 if you have Windows 10 version 1909)
Additional information from therelease health:
Status Originating update History
Confirmed OS Build 19042.867 <br>KB5000802 <br>2021-03-09 Last updated: 2021-03-12, 11:03 PT <br>Opened: 2021-03-10, 06:04 PT
After installing KB5000802, you might receive an APC_INDEX_MISMATCH error with a blue screen when attempting to print to certain printers in some apps. This issue affects a subset of Type 3 printer drivers and does not affect printer drivers that are Type 4. If you are unsure which type your printer driver is, use the following steps:<ol><li><p>Press the Windows key+r or select <strong>Start </strong>and type <strong>run </strong>and select it.</p></li><li><p>Type <strong>printmanagement.msc </strong>and press enter or select the <strong>OK button</strong>.</p></li><li><p>If Print Management opens, continue to step 4. If you receive the error, <strong>Windows can not find 'printmanagement.msc'.</strong> then select <strong>Start </strong>and type <strong>manage optional features</strong> and select it. Select <strong>Add a Feature</strong> and type <strong>print</strong>, select the check box next to <strong>Print Management Console</strong> and select install. You will now need to start at step 1 again.</p></li><li><p>Expand <strong>Print Servers</strong>, expand your computer's name, and select <strong>Printers</strong>.</p></li><li><p>You can now see the Driver Type for each of your installed printer drivers.</p></li></ol>**Workaround:**To mitigate the issue, follow the instructions in this video. The Command Promptcommands from the video are as follows (you will need to replace KX driver for Universal printing with the name of your printer, as explained in the video):<ul><li><p><strong>rundll32 printui.dll,PrintUIEntry /Xg /n “KX driver for Universal printing”</strong></p></li><li><p><strong>rundll32 printui.dll,PrintUIEntry /Xs /n "KX driver for Universal printing" attributes +direct</strong></p></li></ul>Affected platforms:<ul><li><p>Client: Windows 10, version 20H2; Windows 10, version 2004; Windows 10, version 1909; Windows 10, version 1809; Windows 10 Enterprise LTSC 2019; Windows 10, version 1803</p></li><li><p>Server: Windows Server, version 20H2; Windows Server, version 2004; Windows Server, version 1909; Windows Server, version 1809; Windows Server 2019; Windows Server, version 1803</p></li></ul>**Next steps:**We are working on a resolution and estimate a solution will be available in the coming week.
Update 03/15/2021
An out-of-band update KB5001567 is available that fixes the issue.
March 15, 2021—KB5001567 (OS Builds 19041.868 and 19042.868) Out-of-band (microsoft.com)
Highlights
  • Updates an issue that might cause a blue screen when you attempt to print to certain printers using some apps.
Direct download links for Windows 10 20H1 and 20H2:
32 bit:
http://download.windowsupdate.com/d/msdownload/update/software/updt/2021/03/windows10.0-kb5001567-x86_bafeb1bea06a5f39976de3406d3e33fb3cc2c6fe.msu
64-bit
http://download.windowsupdate.com/d/msdownload/update/software/updt/2021/03/windows10.0-kb5001567-x64_e3c7e1cb6fa3857b5b0c8cf487e7e16213b1ea83.msu
107 additional answers
    2021-03-16T12:12:12+00:00
    Having the same exact issue, since new windows up date.    Happens whenever try to print.  Updated all drivers without relief.   Removed, reinstalled printer driver without benefit.  Help!
  2. JuliaMarvin 22,530 Reputation points Volunteer Moderator
    2021-03-17T08:09:44+00:00
    @ everyone whose printing problems did not get fixed by applying the above mentioned out-of-band update
     I suggest reading: Windows 10: Still printing issues after update installation (March 2021) | Born's Tech and Windows World
    as well as this](https://answers.microsoft.com/message/255e5548-5f6f-4ea1-9c7e-844fe53ce525?threadId=39e4db63-9639-4e1e-945c-1f7596070b87 "https://answers.microsoft.com/message/255e5548-5f6f-4ea1-9c7e-844fe53ce525?threadId=39e4db63-9639-4e1e-945c-1f7596070b87") post by moderator  [GBorn .
    That thread got escalated to get the attention of MS.
    You might want to subscribe and/or post to that thread....
    2021-03-17T12:05:43+00:00
    Microsoft released an update that allows re-installation of update KB5000802 and new update KB5001567, fixes issue completely! No more uninstalling, reinstalling anything, no more workarounds. Works great! :) Can see here https://support.microsoft.com/en-us/topic/march-9-2021-kb5000802-os-builds-19041-867-and-19042-867-63552d64-fe44-4132-8813-ef56d3626e14 in a second gray box below "Known Issues..."Seriously, good job, Microsoft folks, with the fix, much appreciated. We all make mistakes, cannot see the future, and this is how you deal with a mistake, fix it in the best way possible as soon as you can.
  4. Sumit 44,316 Reputation points Volunteer Moderator
    2021-03-18T08:06:39+00:00
    New Known issue related to Printing with KB5000802/KB5000808
    Windows 10, version 20H2 and Windows Server, version 20H2 | Microsoft Docs
    Unexpected results when printing from some apps or to some printers
    Confirmed OS Build 19042.867 <br>KB5000802 <br>2021-03-09 Last updated: 2021-03-17, 17:39 PT <br>Opened: 2021-03-17, 17:39 PT
    After installing updates released March 9, 2021 or March 15, 2021, you might get unexpected results when printing from some apps. Issues might include:<ul><li><p>Elements of the document might print as solid black/color boxes or might be missing, including barcodes, QR codes, and graphics elements, such as logos.</p></li><li><p>Table lines might be missing. Other alignment or formatting issues might also be present.</p></li><li><p>Printing from some apps or to some printers might result in a blank page or label.</p></li></ul>Affected platforms:<ul><li><p>Client: Windows 10, version 20H2; Windows 10, version 2004; Windows 10, version 1909; Windows 10, version 1809; Windows 10 Enterprise LTSC 2019; Windows 10, version 1803; Windows 10 Enterprise LTSC 2016; Windows 10, version 1607; Windows 10 Enterprise 2015 LTSB; Windows 8.1; Windows 7 SP1</p></li><li><p>Server: Windows Server, version 20H2; Windows Server, version 2004; Windows Server, version 1909; Windows Server, version 1809; Windows Server 2019; Windows Server, version 1803; Windows Server 2016; Windows Server 2012 R2; Windows Server 2012; Windows Server 2008 R2 SP1; Windows Server 2008 SP2</p></li></ul>
    **Next steps:**We are working on a resolution and estimate a solution will be available in the coming days.
