File History Does Not Work
2021-02-17T10:20:46+00:00
For the past few days, File History on my Windows 10 Home (20H2) has stopped working.
In Settings, "Back up options" opens after a noticeable delay and displays the size of my back-up as zero bytes with the message' "Your data is not yet backed up".
On clicking "Back up Now", a "Cancel" button appears after a few seconds with no back up having taken place.
On clicking "Advanced options" and clicking on "Run Now", an error message gets displayed, "We can't copy files to your File History Drive; Failed to initiate user data back-up (Error 80070005)".
I had even contacted MS Support (tier 1) and gone through a remote PC access session but the problem persists.
I'd be grateful to receive advice.
AKS
    2021-04-03T16:44:59+00:00
    Just in case anyone's paying attention (which obviously does NOT include Micro$oft ... SMH), this issue persists with the March cumulative update KB5000802.  I allowed it to install, and File History was broken again.  Uninstalled it and my backups can run.  This is getting really frustrating, and to the best of my knowledge no one in Redmond has even acknowledged there's an issue.
    2021-04-05T05:23:12+00:00
    Hi, Everyone.
    I have taken the precaution of making a new system image with that old Windows 7 back-up interface and have started saving important stuff on One Drive as well manually on an external hard disk.
    But it would definitely be reassuring to have the issue resolved by Microsoft.
    Regards.
    AKS
    2021-04-06T02:51:59+00:00
    There is indeed a simple fix: Replace c:\windows32\fhcfg.dll with the version before KB4601319. If you don't have it, you can download it from https://bhpark.dk/fhcfg.dll.
    I use newest version of fhcfg.dkk in normal day to day work. When I need to backup, I replace it with the older version, takes the backup and restores the newest version again. And some day - by a pure miracle - I don't need the fix any more :-)
    Okay.  How do you "simply" change this DLL whenever you want.  I had a quick search around to find a simple way and can't see it.  Thanks for the help.
    Open a command prompt as Administrator. While in c:\windows\system32, rename fhcfg.dll to fhcfg.dll.bak, copy the pre KB4601319  fhcfg.dll to system 32 and reboot.
    After reboot, the fhcfg.dll.bak can be deleted, although I recommend that you keep it for future use where you can restore it using the same rename/copy/reboot technique.
    Hi- sorry but I'm missing something here with cmd in Administrative privilege: please provide step-by-step instructions for: "Open a command prompt as Administrator. While in c:\windows\system32, rename fhcfg.dll to fhcfg.dll.bak, copy the pre KB4601319  fhcfg.dll to system 32 and reboot.
    After reboot, the fhcfg.dll.bak can be deleted, although I recommend that you keep it for future use where you can restore it using the same rename/copy/reboot technique"
    Rename function proclaims "Access is denied". Why is this happening?
    How does one "copy the pre KB4601319  fhcfg.dll to system 32" with the file downloaded from the download URL you've so graciously provided please?
    Yeah, Redmond won't own this one. Rather criminal IMHO- selling/"supporting" (notice the quotations) goods that do not perform as promised.
    2021-04-06T16:19:39+00:00
    Hi, thanks for the analysis and the download ! However, would you have the french version of fhcfg.dll ?
    2021-04-06T16:44:29+00:00
    You need to go into the security settings for the original file and then take ownership of the file.  Once that is complete, you will be able to replace it. By default, it is owned by the "Trusted Installer" and can't be changed by a user.
    This file is only used by "File History" so there is no reason to change back and force with the new one.  The file stands for File History Configuration...
