Various BSOD's occuring randomly
2021-02-11T15:22:43+00:00
Hi, I've bought brand new PC and started having random BSOD's while using PC or just when idling on desktop.
I've tried to use Windows Memory Diagnostic, also ran commands /scannow and such in CMD because I read it in so many other topics regarding BSOD.
I've had trouble uploading my dump files so i'll just post results here that I've got in WinDbgPreview.
I did memtest on both RAM drives and they were without errors after 4hr test each.
My specs:
CPU: Ryzen 5 3600
GPU: Gigabyte WF2 RTX 2060
MOBO: Aorus B450 Pro
RAM: XPG 2X8GB 3200MHz
SSD: Kingston A2000 Nvme m.2
HDD: WD 1TB
PSU: FSP Hyper Pro+ 650W
I managed to upload dump files here: https://1drv.ms/u/s!Aq6wDqYiClWbhEgyN5aN5KjPpup_?e=S7n8AY
  1. SD - IA 179.8K Reputation points Independent Advisor
    2021-02-17T02:28:08+00:00
    Thanks.
    To better understand the issue, Please see the article below on how to share System logs.
    http://www.yourwindowsguide.com/2017/12/how-to-...
    Content on the above blog is written by a Microsoft MVP so it is safe. However, do watch out for the ads.
    2021-02-17T06:49:15+00:00
    All done, here's the link https://1drv.ms/u/s!Aq6wDqYiClWbhGUOQnkhnCHRYdiw?e=PNtAjo
    Thank you
  3. SD - IA 179.8K Reputation points Independent Advisor
    2021-02-17T12:19:22+00:00
    Thank you. Apparently, there are multiple problems noted in the logs.
    Please turn off fast startup:
    https://www.tenforums.com/tutorials/4189-turn-o...
    Second,
    Do a System File check and run DISM tool and post back the results in the next reply:
    http://www.yourwindowsguide.com/2016/06/run-sys...
    Content on the above blogs are written by a Microsoft MVP so it is safe.
    2021-02-17T18:57:41+00:00
    I have disabled fast startup, but i have question about power plan. Since i have several options, what do you think is the best and that i should turn on ?
    https://1drv.ms/u/s!Aq6wDqYiClWbhGgKoIiJcmu1ryEP?e=QtX1s0
    Also, i have completed all CMD commands you gave me without errors but few a minutes later i got BSOD DPC_WATCHDOG_VIOLATION
    Here's the link for minidump: https://1drv.ms/u/s!Aq6wDqYiClWbhGknke1DvlbmoNLI?e=82X4Qu
    Thank you
    2021-02-19T09:03:19+00:00
    With regard to your power plan I think the balanced plan you have is good for all round performance. The AMD special plans can be useful if you want to force certain conditions such as the high performance plan will will prevent the CPU from going into low power mode and ensures the Ryzen settings are optimised. However, I think you have the best setting.
    The latest crash can only be analysed properly with the memory.dmp file. If you can share that one it will help me to provide the analysis.
