Various BSOD's occuring randomly
2021-02-11T15:22:43+00:00
Hi, I've bought brand new PC and started having random BSOD's while using PC or just when idling on desktop.
I've tried to use Windows Memory Diagnostic, also ran commands /scannow and such in CMD because I read it in so many other topics regarding BSOD.
I've had trouble uploading my dump files so i'll just post results here that I've got in WinDbgPreview.
I did memtest on both RAM drives and they were without errors after 4hr test each.
My specs:
CPU: Ryzen 5 3600
GPU: Gigabyte WF2 RTX 2060
MOBO: Aorus B450 Pro
RAM: XPG 2X8GB 3200MHz
SSD: Kingston A2000 Nvme m.2
HDD: WD 1TB
PSU: FSP Hyper Pro+ 650W
I managed to upload dump files here: https://1drv.ms/u/s!Aq6wDqYiClWbhEgyN5aN5KjPpup_?e=S7n8AY
    2021-03-06T08:06:52+00:00
    Was there any improvement after the DDU process? If you did not try it the NVCleanstall program is useful to make sure only the latest graphics driver is clean installed. You don't need the GeForce experience and many of the other components. I usually just add the PhysX component.
    2021-03-07T11:46:34+00:00
    I have different error sources now, i will try to use NVCleaninstall and check if it works.
    Here's the link to the latest dumpfiles: https://1drv.ms/u/s!Aq6wDqYiClWbhVQaWxUe5_p-O8A6?e=VGX6kF
    2021-03-07T19:40:49+00:00
    Well there are quite a few different bugcheck codes appearing now. That is always worrying as it tends to imply hardware but let's keep going on the graphics route. NVCleanstall should ensure only the driver gets installed and none of the other software.
    One or two of the crashes feature components of GeForce Experience.
    2021-03-13T07:08:33+00:00
    Hi Phil,
    Here's the newest collection of minidump files after using NVCleanstall. They don't show Nvidia components causing crashes, but random cause, like steam. All these crashes happened while downloading large files.
    2021-03-16T08:31:13+00:00
    Hi nanke15,
    I didn't see any link to the files in your last post.  The good news seems to be that the NVidia related crashes are fixed but you still have those related to network downloads.  That does point to the network drivers and I would continue to look out for updates on the manufacturers websites for these.  Of course seeing the crash dumps will help to narrow it down.
