I have a gaming laptop and have the same problem it is very frustrating.
AirPod Pros Keep Cutting In and Out
I have a pair of AirPod Pros that I've had for a couple of weeks. Every time I connect them, the audio is fine but then a few seconds later the audio keeps cutting in and out. I have tried everything from disconnecting to reconnecting them, updating my Bluetooth driver, and trying everything I've found online but nothing works. The AirPod Pro's work perfectly fine on my phone, but not on my computer. And it's not just YouTube that I'm having the problem with, I tried using Spotify and Netflix with my AirPod Pro's and the audio keeps cutting out there as well. It's extremely frustrating, so if someone could help me I would appreciate it a ton.
2020-12-14T03:22:54+00:00 -
2020-12-17T03:20:06+00:00 I'm having the same issue with my airpods pro. It's extremely frustrating. I can't seem to find any real fixes to this issue
2020-12-27T19:06:53+00:00 lol - have you ever thought about the idea that apple dont want their product (airpods) to work well with Windows, to make you think it's windows that's trash, so you want to buy a mac?
Almost similar to slowing down old iphones with software updates, then blaming it on old batteries....
2020-12-30T04:23:11+00:00 I have the same issue. I suspect this is a Microsoft Windows 10 issue.
2020-12-30T18:38:14+00:00 I am having the same problem, none of these fixes have worked for me at all
