AirPod Pros Keep Cutting In and Out
2020-07-14T03:01:40+00:00
I have a pair of AirPod Pros that I've had for a couple of weeks. Every time I connect them, the audio is fine but then a few seconds later the audio keeps cutting in and out.  I have tried everything from disconnecting to reconnecting them, updating my Bluetooth driver, and trying everything I've found online but nothing works. The AirPod Pro's work perfectly fine on my phone, but not on my computer. And it's not just YouTube that I'm having the problem with, I tried using Spotify and Netflix with my AirPod Pro's and the audio keeps cutting out there as well. It's extremely frustrating, so if someone could help me I would appreciate it a ton.
    2021-04-24T19:09:49+00:00
    Thank you very much. It has worked for me perfectly!
    2021-04-29T18:28:45+00:00
    Same thing on my side.  Mind you it's a Laptop that is managed by my IT department and I need the Admin rights to get to more advanced settings.  That might be where the power management options are.  So still an issue for me.  Tried it yesterday and after 20 min, the sound stopped.
    2021-05-02T14:46:41+00:00
    After dealing with my AirPod Pros intermittently cutting out for months and trying every possible solution, I finally fixed the issue. Unlike the original AirPods, the AirPod Pros require Bluetooth 5.0. I purchased an Asus Bluetooth 5.0 adapter and disabled my standard Dell 4.1 Bluetooth Wireless Card. I haven’t had the issue since. I hope this helps someone!
    2021-05-02T15:41:02+00:00
    My Dell Latitude 7300 seems to have Bluetooth 5.0 and the cuts all the time. I wonder why an external adapter would fix the issue.  It would mean the Intel Wireless bluetooth has a SW issue that could be fixed over the air.  Still waiting for that fix...
    2021-05-03T21:06:26+00:00
    Hey everyone, after working for a couple days with no issues, my AirPod Pros cut out 3 separate times today during my stream. So clearly, the Bluetooth 5.0 adapter didn’t work like I thought it did. Therefore this must be a Microsoft issue, not a hardware issue. Microsoft, please fix this!!
