Browsers wont work on my PC
2020-06-29T15:40:27+00:00
A short while ago I bought a PC [It's a custom PC made for gaming] from a good buddy of mine so I could have one of my own. After setting everything up and sending me on my way, I tried to get a new internet browser for it so I could comfortably do the things I want. I've run into issues with every browser I've downloaded, and neither he or I have been able to solve the issue.
What typically happens is when I click on a browser to launch it [Google Chrome, Opera GX, or Firefox] it will attempt to launch the browser in question, then a tab will pop up and immediately disappear again, seemingly either shutting itself down for some reason, or the browser hiding itself in my background functions, the tab inaccessible. Microsoft Edge and Internet Explorer will work just fine on my computer despite all this. Any and all assistance would be appreciated greatly.
-Blake
2020-06-30T01:50:54+00:00
I dont see any suspect startup processes or running processes as a potential cause ... with one exception. I see a process running called wpcmon.exe. This is otherwise known as the Family Safety Monitor. It has a feature that controls Internet browsing and may have been configured in a way that is preventing the browser from launching. Try killing that process from Task Manager (would likely require administrative privileges) and see if the browser launches.
Incidentally, I can see processes running for microsoftedgecp.exe, which is the legacy version of the Microsoft Edge browser, so currently you should download the latest Edge Chromium browser and install it: https://support.microsoft.com/en-us/help/450109...
46 additional answers
    2020-06-29T23:03:12+00:00
    Nothing in the logs that eludes to the problem.
    Go to %localappdata%\Google\CrashReports. Is there anything in that folder? If so, post. Otherwise, enable the user-mode crash dumps as I mentioned earlier.
    2020-06-29T23:23:12+00:00
    Okay. Is it perhaps possible for you to help me further with the Dump setups? This whole thing is quite confusing to me.
    2020-06-29T23:42:11+00:00
    modify the registry as eluded in the link I sent you or go to https://1drv.ms/u/s!ApX1j7el8hb3gXoVRJjP9kKQFYs... t download the .reg file. Double-click it to merge the reg settings into your registry (requires admin permissions). Afterwards, restart the computer, reproduce the issue, go to %localappdata%\CrashDumps in explorer and upload the .dmp files that were (hopefully) created.
    2020-06-30T00:08:02+00:00
    So I merged the Reg files as you instructed, restarted my pc, and proceeded to recreate the issue. Despite all this, no .dmp files have been created anywhere in my system. I looked everywhere I can think and even swept the entire computer for any .dmp files, but nothing came up. Do you perhaps have any ideas as to why this may occur?
