Browsers wont work on my PC
2020-06-29T15:40:27+00:00
A short while ago I bought a PC [It's a custom PC made for gaming] from a good buddy of mine so I could have one of my own. After setting everything up and sending me on my way, I tried to get a new internet browser for it so I could comfortably do the things I want. I've run into issues with every browser I've downloaded, and neither he or I have been able to solve the issue.
What typically happens is when I click on a browser to launch it [Google Chrome, Opera GX, or Firefox] it will attempt to launch the browser in question, then a tab will pop up and immediately disappear again, seemingly either shutting itself down for some reason, or the browser hiding itself in my background functions, the tab inaccessible. Microsoft Edge and Internet Explorer will work just fine on my computer despite all this. Any and all assistance would be appreciated greatly.
-Blake
2020-06-30T01:50:54+00:00
I dont see any suspect startup processes or running processes as a potential cause ... with one exception. I see a process running called wpcmon.exe. This is otherwise known as the Family Safety Monitor. It has a feature that controls Internet browsing and may have been configured in a way that is preventing the browser from launching. Try killing that process from Task Manager (would likely require administrative privileges) and see if the browser launches.
Incidentally, I can see processes running for microsoftedgecp.exe, which is the legacy version of the Microsoft Edge browser, so currently you should download the latest Edge Chromium browser and install it: https://support.microsoft.com/en-us/help/450109...
46 additional answers
    2020-06-29T16:29:25+00:00
    It's okay if it's not possible. let's try to sort this out, please bear with me. may I please know if those browsers are newly installed? and if ever you have a running antivirus in your system, can you disable it first then try to run the browsers again
    2020-06-29T16:37:34+00:00
    The browsers were just downloaded last night. I've uninstalled and reinstalled them at least twice per browser to no avail. I don't currently have and antivirus that I am explicitly aware of, so any protection on my pc is through whatever Windows may have in the OS itself.
    2020-06-29T16:54:34+00:00
    may I please know the version of your Windows 10?
    2020-06-29T17:05:53+00:00
    It appears to be version 1903, OS build: 18362.900
