High performance Power plan missing.
2020-06-07T09:16:10+00:00
Hi, i have a surface laptop and i cant change my performance in power options in control panel, it would just show balanced for me, and when i press create a new power plan i cant see high performance, it only shows balance, i need a way to get high performance can anyone please help me?
***Original Title: Power***
Windows for home | Windows 10 | Sleep and Power on, off
2020-07-26T14:07:19+00:00
This is a temporary fix i guess, but it works for me nonetheless
using the command:
"powercfg -duplicatescheme 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c"
does not add the plan high performance in this power plan. So i ended up forcing the plan to run from cmd with this code:
"powercfg -s 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c"
and create the ".bat" file to have a launcher so i don't have to type whenever i need to use the plan. The plan runs after couple seconds of delay and appear alongside with "balanced plan". If you change the plan to the original one, the high performance one will dissapear so you need to launch the code again.
73 additional answers
    2020-06-08T11:55:52+00:00
    Thank you for writing to Microsoft Community Forums.
    We understand the concern as you are unable to create a new power plan with high performance.
    In order to get clarity and to assist you accordingly, please reply with the answers to the questions below:
    • What is the Version and Build of Windows 10 installed? (Type winver in Windows search/Run command)
    • Is the PC connected to a domain/organization network?
    Meanwhile, we would suggest you to perform these steps to restore the default power plans on the PC.
    1. Click on Start menu and type CMD, right click on CMD and select Run as Administrator.
    2. Type the following command and press Enter: powercfg –restoredefaultschemes
    3. Once the process is complete, then restart the PC and check
    If the issue persists, then perform these registry changes and check..
    Note:  Important this section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs.
    Follow the steps to take backup of registry
    1. Open the Run dialog box by pressing the Windows key and the R key together.
    2. Type Regedit and hit the Enter key.
    3. When the Registry Editor opens, navigate to the following location: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power
    4. In the right pane, double click on the DWORD entry named CsEnabledand****set it to 0.
    5. Click Ok and restart the PC to check.
    Let us know the results. We will certainly assist you further.
    Aditya Roy
    Microsoft Community – Moderator
    2020-06-10T09:10:25+00:00
    Hello.
    I have the same problem.
    I'm running the 2004 build (19041.264).
    When trying to do what you offered the CsEnabledand entry does nor exist.
    What can I do?
    Thank you in advance,
    Hemi
    2020-06-22T09:56:25+00:00
    I have the same exact problem.
    The solution offered by Aditya_Roy on June 8, 2020 does not help, as CsEnabled does not exist.
    Is there an actual solution to the problem?
    Thanks.
    2020-06-28T17:29:25+00:00
    Windows 10 May update (2004) REMOVEDCsEnabled from the registry. Come on Microsoft give it back please.
