Intel SCSI Adapter update causes boot problems
2020-06-08T15:27:48+00:00
I rec'd an Intel SCSI Adapter update V 17.5.3.1026, this AM, thru the Windows update screen. After the install I immediately has boot up problems. The boot up would stall at the Dell logo screen and go no further. I was able to get to boot up once in a while by powering off and restarting from the power button, but that didn't work very often. When it did boot up using this method it was pretty sluggish. I contacted Dell support and they were not aware of the problem. I subsequently reviewed some Dell community forum posts and there were other people reporting the exact same problem in May 2020.  I was finally able to get back to normal operating condition by doing a system point restore prior to the download. The jist of the forums was there is problem with the RST and BIOS not in sync. Both of those are current according to Dell drivers and download screen.  Dell has fowarded the problem to the engineering dept for review. The next time I checked for updates the Intel showed up again but I did not install. I'm OK as long as it does not try to self install. I also contacted MS support and they wanted to update me V 2004 which I declined as it still is showing for developers. Any thoughts on what to do here? Thanks
2020-06-15T10:07:52+00:00
I have experienced the same issue on my Dell XPS 8920 tower, because I was aware that an intel driver was updated before the issue. So I did a driver roll back inside device manager. And everything has back to normal now. So ABSOLUTELY no need for a system restore! just roll it back
2020-06-13T12:18:05+00:00
I had the same issue with it crashing when w10 starts up or from hibernation after a windows update which is bundled with an Intel driver update and believe I've solved it.
I am no expert and cannot vouch for any side-effects but I found the newly installed Intel driver, rolled it back and now I no longer have any start-up issues.
Go to Device manager>Storage Controllers>Intel(R) Chipset SATA.....>Properties>Driver>Rollback Driver.
No more problems with start-up
81 additional answers
    2020-08-15T14:37:37+00:00
    Thank you for your comments. I disabled " fast startup" as you suggested and it booted up with no issues. A little slower on boot up but it did not stall. The other solution that I inadvertenly discovered is if on power up I hold the power button in for about 5 secs it boots up normally. Not sure why that works, but, it's another workaround until Dell solves this issue. Thanks
    2020-08-17T17:24:00+00:00
    The engineers at Dell suggested that I disable the W10 driver download feature in System & Security as a way to prevent any Intel Driver update et al from downloading in the future. Sounds simple to me. Any comments? Thanks
    2020-08-17T17:56:21+00:00
    Where exactly is this setting?  I cant find it.  Thx
