snip and sketch not working
2020-07-01T12:16:12+00:00
My snip and sketch tool has stopped working. I open the app, select new, highlight the area to snip but then nothing happens. I have tried refreshing the app and uninstalling and reinstalling but neither have resolved the issue.
    2021-01-30T15:04:00+00:00
    Here's a re-post of the solution that worked for me.  Been months now and Snip and Sketch still works after various Win10 updates.  No re-install.  No jumpin' through hoops, waving chicken bones, etc.
    I stumbled upon a fix for the "snip" problem I was having.
    I wanted to change a notification for an unrelated app in settings.  I happened to notice that notifications were turned off for Snip & Sketch (pretty sure I didn't do this), but maybe latest update did??  Anyways I turned notifications on for snip & sketch and "snip" worked for me again.
    Hope this might help others.
    2021-01-30T23:09:32+00:00
    Thanks for the reply.
    I have checked on my home PC where I am having this issue and I can't see skip and sketch in the notification area at all.
    I can see it on my work PC where the app works fine.
    I will investigate further...
    2021-01-31T08:51:51+00:00
    Further to this.
    I have since checked my pc at home and the snip & sketch notification is on for banners, sounds.
    It still fails to completely start and just stays on for a second or two.
    2021-02-14T17:03:49+00:00
    No, that stopped working for me at home. On my work PC that is the way it functions. A solution I found, as noted above, is to hit Win-A after taking the Snip. This opens up a bar on the right to allow editing. As a bonus, this can be done at any point afterward and doesn't have to be done immediately.
    2021-02-14T17:06:50+00:00
    Are you able to take the Snip but not have it available to edit? That was my problem. I have documented the solution here, but in a nutshell, hit Win-A after taking the Snip. A bar will pop up on the right allowing you to use it.
