You are welcome. Glad to hear it, & thanks for the feedback.
Documents disappearing from print queue and not printing
I am using a Brother DCP-195C printer. The printer is working - I can monitor ink levels etc from the Brother Control centre on my PC but I can't print.
2020-06-16T08:53:09+00:00 -
2020-06-16T09:05:54+00:00 Windows did another update to v2004 and the printer stopped printing again. I had to uninstall update KB4557957 as well to get it working again.
2020-06-16T11:00:06+00:00 I love you so much boys!!!! Great job, my Hp designjet 450c is working fine another time. I unistalled the Update For 1903/1909 nº KB4560960 and all goes well. I have spent a few bad days with my plotter playing everything.
Grettings from Valencia, Spain!!!!
Miguel
2020-06-16T21:57:40+00:00 Thanks for the heads-up.
(1) Yep, it's fixed (addressed) in 1903/1909...
https://support.microsoft.com/en-us/help/4567512
June 16, 2020—KB4567512 (OS Builds 18362.904 and 18363.904)
"Addresses an issue that might prevent certain printers from printing. The print spooler might generate an error or close unexpectedly when attempting to print, and no output will come from the affected printer. You might also encounter issues with the apps you are attempting to print from, such as receiving an error, or the app might close unexpectedly. This issue might also affect software-based printers, such as when printing to PDF."
Everyone should click for it at Windows Update. After installation (or maybe even before) the predecessor that is blocked in WUShowHide will I think automatically disappear from it.
(2) But 2004 didn't get an update that I can see. The latest is still...
https://support.microsoft.com/en-us/help/4557957
June 9, 2020—KB4557957 (OS Build 19041.329)
And it still reports the same problem...
After installing this update, certain printers might fail to print. The print spooler might throw an error or close unexpectedly when attempting to print, and no output will come from the affected printer.<br><br><br>You might also encounter issues with the apps you are attempting to print from. You might receive an error from the app or the app might close unexpectedly.<br><br>Note This issue might also affect software-based printers, for example printing to PDF. Microsoft is working on a resolution and will provide an update when more information is available. But lucky for me, my own Brother MFC-L2740DW was immune in 1909 & remains immune in 2004. I upgraded last night & still can print.
2020-06-17T10:08:05+00:00 I've already uninstalled KB4560960 but my documents still won't print... Can someone help?
