Thank you, Alireza! My MFC-495CW printer recently stopped printing jobs sent from my PC, but I could still scan documents and send them to my PC. After uninstalling and re-installing the printer, the problem remained.
Your simple and clear solution, tested by other readers, worked like a charm! In my case, I uninstalled KB4560960 and restarted my computer. All is now well...
And thank you "PCR just PCR": with your help, the update will no longer automatically install by itself...
Thanks again, to both!!
