I hear what you are saying about a Macrium Reflect image but here is my reality. I did not boot my computer using Macrium Reflect media. I let my computer boot up as it normally does from the hard drive. I used the Macrium Reflect app to restore an image stored on a separate disk drive plugged into USB. The restore was successful and my computer is functioning as I am accustomed to. It doesn't appear to me why a Macrium Reflect recovery cd/dvd disk would be necessary unless it provides some insurance.
System Repair Disc Not Bootable in Win10
I am running Win 10 Pro 64bit version 1909. I used Control Panel, System and Security, Backup and Restore (Windows 7) to create a system repair disc. That worked fine, no error messages, until I went to use it. I tried to boot my pc from the CD drive where the repair disc was inserted but got an error message, non system disc or words to that effect. I had done this previously with Win7 without any problem. Any thoughts as to why the same process is not working in Win10?
2020-07-20T13:12:00+00:00 -
2020-07-20T13:41:01+00:00 Hi,
I am actually quite surprised to hear that you were able to do that.. Did you restore the image to the drive that was currently running Windows ? I will need to look into that further.. Personally, I would think you may get better results using the bootable Macrium, but maybe not..
But yes, regardless, the bootable Macrium CD or Flash Drive is good insurance..
Obviously, you can not run the Macrium App from within Windows if the compute will not boot to the installed drive(s)..
2020-07-21T19:31:49+00:00 I couldn't agree with you more about the instability and unreliability of Win7 Backup and Restore which was migrated to Win10 and you alluded to back on 07/12/20. I spent the greater part of two days and a night trying the different options that are available for using the repair/recovery/restore processes available. I was met with limited success that I don't trust but mostly error messages and system failures that I couldn't get past except to rebuild my computer from scratch using installation media that I had never used before. My saving grace has been Macrium Reflect. It is quicker and more comprehensive than Windows, which is convoluted and scattered. But most of all, Macrium Reflect provides the assurance that what it does I can hang my hat on.
2020-07-21T19:41:31+00:00 Yes, I did restore the system image to the C drive that Windows resides on. Again, no bootable media from Macrium Reflect was used. I powered up my computer with nothing in the CD/DVD drive, booted from the hard drive as I normally do, fired up the Macrium Reflect app and restored the C drive image from an external disk drive plugged into USB. The results are exactly what I expected them to be. My computer looks and runs fine. So, bye-bye Windows Backup and Restore and hello Macrium Reflect.
