Mapped Drive will not connect after reboot
2020-07-24T15:46:02+00:00
After a recent windows update I have had multiple issues with my network drives on my home network.  Some of these were caused by my router which I have replaced.  Now I have all but one drive working correctly.  I cannot figure out the one remaining problem.
If I map the drive by the name (\MyBookWorld\Public) the map works OK until I reboot.  After reboot, I get the error of "The Specified network name is no longer available".  I cannot connect to drive via start>>run either.  If I try to access the drive by IP address using start>>run, it works.
If I disconnect the map drive and reboot, I can connect from start run to the drive after every reboot.
If I map the drive by IP address, reboot and then try to use the drive, I get "Microsoft Windows Network:  The local device name is already in use".  Net use shows the drive disconnected and has an entry to the unc name.  It works if I use start>>run to the UNC name.
I have verified that smb is enabled on the machine.  I have made sure the services of "comptuer browser", "LanmanServer", and "LanmanWorkstation" are set to automatic start.
I have removed the mapping, made sure that it was not in the net use list in the command prompt and made sure the registries at HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2 for this drive have been removed.
I have added the mapping to the Hosts file.
I tried mapping to a different drive letter and get the same problem.  Any ideas on what in Windows is messing this up?
    2021-01-06T01:24:42+00:00
    I built this little batch file:
    NET USE Z: /DELETE
    NET USE W: /DELETE
    NET USE X: /DELETE
    NET USE Y: /DELETE
    NET USE W: \192.168.42.71\sharename /persistent:Yes
    NET USE Y: \192.168.42.70\sharename /persistent:Yes
    NET USE Z: \192.168.42.11\sharename /persistent:Yes
    NET USE X: \192.168.42.12\sharename /persistent:Yes
    then used run -> shell:startup
    and copied the batch file into the window that opened.
    This runs as me, not as admin, and so far has worked on my desk machine and our laptop.
    I put in the /persistent option as a "just in case".
    2021-01-06T08:23:04+00:00
    Hi!
    Thank you for the tip.
    My solution with the correction of the date on the NAS only lasted for a few days. :-)
    Got another tip now to use the IP Address to the NAS and not the name, and this has worked today. I'll test it for a few more days to see what happens.
    2021-01-06T15:49:26+00:00
    Thanks John,
    I had thought about maybe trying a batch file to "remap" the NAS drives at every reboot. However, having not done batch files since DOS days, I didn't know how to proceed. I will certainly try yours, adjusted for my system. But first, how did you arrive at the IP addresses for each network drive? The 192.168 part is clear to me; but how one determines the other two parts isn't. Is it arbitrary, or is there some process to suss out just what they need to be?
    2021-01-06T16:23:53+00:00
    I have posted this before and it has worked perfectly for me and other users for some time now after trying almost every other method. It's a little complex and you do have to follow every step. If you are not clear about any step reply and I will try to help.  This does depend on being on a domain.
    I have solved this for a number of users by setting up a Group Policy for mapped drives on the server.
    These are the steps:
    Group Policy Management | Default Domain Policy-Edit | User configuration | Preferences | Windows Settings | Drive Maps create new mapped drive -Action Replace - Reconnect ticked- make sure that mapping is targetted to the users that you need.
    Turn off reconnect mapped drives at sign-in locally.
    Now each time a user signs in the drives are mapped with no conflicts.
    2021-01-07T07:55:31+00:00
    Standard local IP Range for home users are normally 192.168.0.xxx or 192.168.1.xxx where xxx is the number for the device. If you are on a office network, the IT department can give you the IP for the Drive.
    As how to find it, depends on where the mapped drive is located. In my instance the IP is available on the display on the NAS, but you could also access it from you Router under DHCP settings.
    Below is an example. If you know the MAC Address too it helps.
