Mapped Drive will not connect after reboot
2020-07-24T15:46:02+00:00
After a recent windows update I have had multiple issues with my network drives on my home network.  Some of these were caused by my router which I have replaced.  Now I have all but one drive working correctly.  I cannot figure out the one remaining problem.
If I map the drive by the name (\MyBookWorld\Public) the map works OK until I reboot.  After reboot, I get the error of "The Specified network name is no longer available".  I cannot connect to drive via start>>run either.  If I try to access the drive by IP address using start>>run, it works.
If I disconnect the map drive and reboot, I can connect from start run to the drive after every reboot.
If I map the drive by IP address, reboot and then try to use the drive, I get "Microsoft Windows Network:  The local device name is already in use".  Net use shows the drive disconnected and has an entry to the unc name.  It works if I use start>>run to the UNC name.
I have verified that smb is enabled on the machine.  I have made sure the services of "comptuer browser", "LanmanServer", and "LanmanWorkstation" are set to automatic start.
I have removed the mapping, made sure that it was not in the net use list in the command prompt and made sure the registries at HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2 for this drive have been removed.
I have added the mapping to the Hosts file.
I tried mapping to a different drive letter and get the same problem.  Any ideas on what in Windows is messing this up?
    2021-05-06T12:03:16+00:00
    I haven't been able to find a solution since September.   Well one was to restart 2 times and that would work.  But had a user yesterday couldn't access the drive even after reboot 3 times.  I couldn't even disconnect the drive explorer would hang.  Even tried net use to delete the drive nothing.
    So since I could browse the path I added to quick access and she was able to access it that way, while the mapped drive to same location still didn't work.
    Then I stopped Workstation service as you said, then started it.    Instantly I was able to access all the shared drives including the already mapped drives to nas.   Then I restarted 4 times and at no time did I lose access.   It's so strange that restarting the PC didn't have the same affect as stopping this services and starting it up.   It must clear something when stopped.
    2021-07-23T20:25:43+00:00
    I think the path should be
     HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>Windows>CurrentVersion>Policies>System.
    This seemed to work for me so far
