Trouble in installation of DSS Catia DS License Server
2020-06-27T14:15:26+00:00
I need support in order to resolve issue related to installation of CATIA software.
One need to install DS License server administration Tool in order proceed further with actual installation of application.
First i tried installing Catia V5-6R2017.....when i installed DSS License server Administration.... a License Administration Tool is supposed to pop up automatically after installation.....but same didn't happen. I tried installing it multiple time, still nothing.
When i ran Catia V6R2012, License Administration Tool appeared automatically after installation of DS License Server Administration.
How can i run V2017 of Catia ??...pls help
(Pls respond if more information required regarding issue)
(System Info:
  1. Windows 10
  2. 64bit
  3. 8 GB RAM
  4. 4 GB NVIDIA GTX 1050 graphics)
2020-09-27T17:43:29+00:00
hi
please foloowing this step:
for persian people:
با سلام. لططفا مراحل زیر رو دنبال کنید. من انجام دادم و جواب گرفتم. سوالی هم بود میتونید همینجا بپرسید
۱. Install dslic. The admin gui tool will not work
۲. Run CMD as admin, change directory to where DSLicSrv.exe is
۳. dslicsrv /test -admin
this will change the cmd prompt as commands from now on are related to dslicsrv
۴. c localhost 4084
this will give you your computerid. it is also present in log files in %programdata%\DassaultSystemes\LicenseServer\LogFiles
you will have to run the license generator in win10 1909 or earlier. not on 2004.
generate license, and copy the file to the win10-2004 computer, to the same directory as dslicsrv
۵. e -dir .\ -file filename.licz
where filename is the license file name obviously
this command enrolls the licenses into the server
۶. sc -lp 4085
then type yes
I had to give this command before the next
it probably defines the lic port.
۷. sc -els yes
then type yes
۸. gsi
this give you info on how the server is working.
admin >gsi
Software version: 6.419.9
Build date: Jun 20, 2017 3:55:24 PM
Standalone mode
Ready: yes
Server name: name Server id: KUK-4214560057E15406
80 additional answers
    2020-09-19T09:11:24+00:00
    i had same problem.
    with going back to previous version of windows the problem solved.
    like this:
    [windows update
    view update history
    recovery options
     go back to previous version of windows 10]
    2020-10-01T11:34:46+00:00
    سلام
    میشه مراحل رو دقیق بگید باید چی کار کرد.
    2020-10-10T01:15:17+00:00
    Hey Prashant,
    were able to launch the v5 with windows -2004 I am facing the same issue.
    2020-10-10T15:01:50+00:00
    1-      Run CMD as admin
    2-      change directory to where DSLicSrv.exe
    برای تغییر مسیر ابتدامسیری که DSLicSrv.exeدر آن وجود دارد را کپی کنید و سپس در سی ام دی مانند متن زیر تایپ کنید
    cd C:\Program Files (x86)\Dassault Systemes\DS License Server\intel_a\code\bin
    در این مثال فایل در مسیر
    بوده و قبل از مسیر عبارت
    Cd
    تایپ شده است
    عبارات زیر را در cmdتایپ کنید و بعد از هر مرحله اینتر بزنید
    3-      dslicsrv /test -admin
    4-      c localhost 4084
    5-      e -dir .\ -file filename.licz
      filename:: این نام فایل کلید هایی میباشد که قبلا با استفاده ازgenerat licenceتولید شده است
    این فایل را در همان مسیر DSLicSrv.exeقرار دهید.
    در صورتی که این فایل را ندارید در ویندوز ده دیگری با بیلد پایینتر از 2004 بسازید. دقت شود که باید با نام کامپیوتر خودتان ساخته شود
    6-      sc -lp 4085
    7-      yes
    8-      sc -els yes
    9-      yes
    10-   gsi
    بعد از آخرین مرحله پیغام زیر نمایش داده میشود
    admin >gsi
    Standalone mode
    Ready: yes
