Trouble in installation of DSS Catia DS License Server
2020-06-27T14:15:26+00:00
I need support in order to resolve issue related to installation of CATIA software.
One need to install DS License server administration Tool in order proceed further with actual installation of application.
First i tried installing Catia V5-6R2017.....when i installed DSS License server Administration.... a License Administration Tool is supposed to pop up automatically after installation.....but same didn't happen. I tried installing it multiple time, still nothing.
When i ran Catia V6R2012, License Administration Tool appeared automatically after installation of DS License Server Administration.
How can i run V2017 of Catia ??...pls help
(Pls respond if more information required regarding issue)
(System Info:
  1. Windows 10
  2. 64bit
  3. 8 GB RAM
  4. 4 GB NVIDIA GTX 1050 graphics)
2020-09-27T17:43:29+00:00
hi
please foloowing this step:
for persian people:
با سلام. لططفا مراحل زیر رو دنبال کنید. من انجام دادم و جواب گرفتم. سوالی هم بود میتونید همینجا بپرسید
۱. Install dslic. The admin gui tool will not work
۲. Run CMD as admin, change directory to where DSLicSrv.exe is
۳. dslicsrv /test -admin
this will change the cmd prompt as commands from now on are related to dslicsrv
۴. c localhost 4084
this will give you your computerid. it is also present in log files in %programdata%\DassaultSystemes\LicenseServer\LogFiles
you will have to run the license generator in win10 1909 or earlier. not on 2004.
generate license, and copy the file to the win10-2004 computer, to the same directory as dslicsrv
۵. e -dir .\ -file filename.licz
where filename is the license file name obviously
this command enrolls the licenses into the server
۶. sc -lp 4085
then type yes
I had to give this command before the next
it probably defines the lic port.
۷. sc -els yes
then type yes
۸. gsi
this give you info on how the server is working.
admin >gsi
Software version: 6.419.9
Build date: Jun 20, 2017 3:55:24 PM
Standalone mode
Ready: yes
Server name: name Server id: KUK-4214560057E15406
80 additional answers
    2020-12-08T10:52:51+00:00
    Hi jier1,
    Check in Task Manager if the DS license server is running.
    If not, find the DS License Server on the Services tab, right click and select run.
    If you can't find the DS license Server in the Task Manager Services tab, reinstall the DS license server an try again.
    //X
  2. Deleted
    2020-12-10T13:30:10+00:00
    thank you for your answer,
    i reinstalled DS License Server and everything is working !!!
    In addition to, i made a mistake during the steps cause my windows language is french and it make difference beetwen "yes" and "oui" ;)
    Needed to launch license generator on W10-1909 cause it crash on W10H2.
    2020-12-13T11:54:16+00:00
    Hi saeedqahremani,
    I applied what you write here , everything is OK ; I can see the server start ;
    Software version: 6.418.2
            Build date: 05.Şub.2016 23:28:17
            Standalone mode
            Ready: yes
            Server name: keremmonster   Server id: ZYP-41FE1000CF9B216E
    but when I click and open the CATIA , still it can not see the licenses , what should I do?  Please help me
