Crackling audio after update to 2004
2020-06-21T01:57:04+00:00
After updating Win10 to 2004, I get crackling audio when I use Razer Surround Pro software. When I switch my audio output, I get normal audio. This only happens when I use Surround Pro.
Edit: Still talking with razer support but I ultimately believe this is an issue with the 2004 update. I hope there's a fix for this soon, although I don't mind still using 1909.
Edit: this is the reply from Razer I got today:
Good day!
We receive an update from our appropriate department that our Audio team is checking on the path forward. Should there be a fix, it will come in the form of a software update. Please check the synapse update from time to time.
Thanks.
Edit: I don't understand why, but having bluestacks running in the background fixes the issue.
    2020-12-10T04:51:28+00:00
    I have the same issue, just updated to 20H2 hoping for a fix but nah
    2021-01-02T16:42:05+00:00
    I don't remember what version of Windows I had but before my memory card failed everything was ok.  Now i have new storage card, reintstalled Windows and later Razer Surround and when it's on, all audio is permanently crackling.
    Now i have 20H2 too and i don't know what to do next.
    2021-01-02T17:10:59+00:00
    Download 1909 for that easy
    2021-01-02T18:54:52+00:00
    https://www.youtube.com/watch?v=P2CIpb-NeIk&t
    I have the same "sound" noise like that on the video and so I downloaded BlueStacks too. Everything works good now
    Maybe I could go back but I don't know how to come back to 1909 because I have fresh new windows with this update already (20H2)... I don't know if this even possible.
    But thank you for solution :)
  5. Deleted
