Crackling audio after update to 2004
2020-06-21T01:57:04+00:00
After updating Win10 to 2004, I get crackling audio when I use Razer Surround Pro software. When I switch my audio output, I get normal audio. This only happens when I use Surround Pro.
Edit: Still talking with razer support but I ultimately believe this is an issue with the 2004 update. I hope there's a fix for this soon, although I don't mind still using 1909.
Edit: this is the reply from Razer I got today:
Good day!
We receive an update from our appropriate department that our Audio team is checking on the path forward. Should there be a fix, it will come in the form of a software update. Please check the synapse update from time to time.
Thanks.
Edit: I don't understand why, but having bluestacks running in the background fixes the issue.
    2020-10-18T01:01:55+00:00
    This is the answer i got!
    This is ridiculous! Guess I'll try the bluestacks thing.
    2020-10-18T05:38:47+00:00
    That is also the reply I receive from them... Looks like it is up to Microsoft if they will fix the issue or not.
    2020-10-19T02:13:03+00:00
    I just updated from Windows 10 2004 to Windows 10 version 20H2 and sad to say, the problem still persist.
    2020-10-21T13:53:06+00:00
    Yes, I can confirm that too.
    2020-10-28T21:30:49+00:00
    The problem still persist at my NTB too and next problem after update to Windows 10 version 20H2 is error Code: 0x80070141 with Gears 5 in MS Store.  MS... MS...   it is way to hell........    :-( :-(
