Firmware protection off and button grayed out
2024-01-07T04:08:09+00:00
I enabled firmware protection via Group Policy editor, but when I went to windows security the firmware protection button was off and grayed out with a message "This setting is managed by your administrator."
I want the fix and turn on Firmware protection
    2024-01-08T11:53:07+00:00
    No emulator running sir
  2. DaveM121 933.9K Reputation points Independent Advisor
    2024-01-08T11:55:50+00:00
    Something you have installed has caused Hyper-V to not be enabled, you need to enable that for Firmware Protection to be used.
    Open Command Prompt as Administrator, then run this command
    bcdedit /set hypervisorlaunchtype auto
    Restart your PC then try enabling Hyper-V
    2024-01-08T12:14:43+00:00
    Sir from where to enable Hyper V
  4. DaveM121 933.9K Reputation points Independent Advisor
    2024-01-08T12:18:01+00:00
    Open the old Control Panel, then set View to icons at the top
    Open Programs and Features in the old Control Panel
    On the left, click 'Turn Windows Features on or off'
    In there you will find the Hyper-V setting.
    2024-01-08T12:35:38+00:00
    Sir my processor is Intel(R) Core TM i5-10400F
    Cpu is H410M S2 V2
