KB5034441 update problem, error (0x80070643).
2024-01-10T15:18:19+00:00
I have tried to update and I get error 0x80070643 with update KB5034441. I have tried uninstalling the Windows update, restarting the Windows Uptade service, deleting the update files and I have also run the following commands:
DISM /Online /Cleanup-Image /CheckHealth
DISM /Online /Cleanup-Image /ScanHealth
DISM /Online /Cleanup-Image /RestoreHealth
DISM.exe /Online /Cleanup-Image /RestoreHealth /Source:C:RepairSourceWindows /LimitAccess
DISM /Online /cleanup-image /startcomponentcleanup
sfc /scannow
chkdsk C: /f
But nothing has fixed the problem
2024-01-11T18:16:15+00:00
The update KB5034441 failed with a fatal error when staging the WIM. This is due to a lack of free space in the WinRE partition. KB5034441: Windows Recovery Environment update for Windows 10, version 21H2 and 22H2: January 9, 2024 - Microsoft Support
Resizing the Recovery partition to 750 MB resolves the issue. That applies if you use the Windows-default winre.wim.
For OEM-supplied winre.wim (which has additional drivers and packages), ensure the Recovery partition's size is atleast 100 MB more than the size of the custom wim.
KB5028997: Instructions to manually resize your partition to install the WinRE update - Microsoft Support: https://support.microsoft.com/en-us/topic/kb5028997-instructions-to-manually-resize-your-partition-to-install-the-winre-update-400faa27-9343-461c-ada9-24c8229763bf
Note: The above MS article works only if your Recovery partition is situated next to (i.e., right side) the OS partition. You can check the disk layout by opening Disk Management.
(Based on what I've noticed on the forums, many users have decided to skip/hide the KB5034441 update and wait and see if Microsoft releases a fix.)
After command SFC /scannow
& resize of WinRE to 1GB, managed to get this update working. 👍
86 additional answers
    2024-01-18T20:50:35+00:00
    Even following the MS instructions and resizing the WinRE to 2GB, I could never get this update to work, until I discovered a problem with the Microsoft instructions. This applies if your disk is MBR. It may apply to GPT too, but I do not know.
    I created the new recovery partition per the instructions "create partition primary id=27".
    Command "List Part" displays the recovery partition created successfully.
    Notice how just after creating the partition, "list part" displays the partition type as "recovery",
    Then I formatted the partition as instructed, "format quick fs=ntfs label=”Windows RE tools”.
    However, the act of formatting the partition changed the partition type from recovery to primary.
    Notice now that after the format command, "list part" displays the partition type as "primary".
    It is necessary to do another not-mentioned command to reset the partition type back to recovery "set id=27".
    Now, "list part" displays the partition type as "recovery", as it should.
    After that, the update finally worked. Below is the command sequence that demonstrates this:
    DISKPART> delete partition override
    DiskPart successfully deleted the selected partition.
    DISKPART> create partition primary id=27
    DiskPart succeeded in creating the specified partition.
    DISKPART> list vol
      Volume ###  Ltr  Label        Fs     Type        Size     Status     Info
      Volume 0     R                       CD-ROM          0 B  No Media
      Volume 1         System Rese  NTFS   Partition    549 MB  Healthy    System
      Volume 2     C   DRIVE_C      NTFS   Partition     87 GB  Healthy    Boot
    * Volume 4                      RAW    Partition   2002 MB  Healthy    Hidden
    DISKPART> list part
      Partition ###  Type              Size     Offset
      Partition 1    Primary            549 MB  1024 KB
      Partition 2    Primary             87 GB   550 MB
    * Partition 3    Recovery          2002 MB    88 GB
    DISKPART> format quick fs=ntfs label="Windows RE tools"
      100 percent completed
    DiskPart successfully formatted the volume.
    DISKPART> list part
    * Partition 3    Primary           2002 MB    88 GB
    DISKPART> select partition 3
    Partition 3 is now the selected partition.
    DISKPART> set id=27
    DiskPart successfully set the partition ID.
    DISKPART> list part
    DISKPART> list vol
      Volume 3                      NTFS   Partition   2002 MB  Healthy    Hidden
    DISKPART> exit
    Leaving DiskPart...
    C:\>reagentc /enable
    REAGENTC.EXE: Operation Successful.
    C:\>reagentc /info
    Windows Recovery Environment (Windows RE) and system reset configuration
    Information:
        Windows RE status:         Enabled
        Windows RE location:       \\?\GLOBALROOT\device\harddisk0\partition3\Recovery\WindowsRE
        Boot Configuration Data (BCD) identifier: f36b9bfc-a794-11ea-8490-ea09138c8692
        Recovery image location:
        Recovery image index:      0
        Custom image location:
        Custom image index:        0
    2024-01-19T06:28:50+00:00
    please fix this error ***43 and ***441
    windows is becoming a real problem
    this is bad planning and programming from microsoft
    I do not have time to read many web pages of stupidity
    FIX THE PROBLEM PLEASE
    2024-01-20T08:49:56+00:00
    All these hot shots with their ways to fix this problem. First it was run the update troubleshooter .Of course it does not even know there's a problem. Then it was the Sfc scannow. Which also does not find anything. Then the Dimm and all the others which 90+% do not understand and its Microsoft update which needs to be repaired by them. When? Us PC users just want it fixed and all the problems that it causes. Almost 2 weeks has gone by and nothing.
    2024-01-20T14:23:59+00:00
    DO NOT CALL ME A "HOT SHOT".
    I told you of an omission in the Microsoft instructions. The act of formatting the newly created recovery partition - per Microsoft's instructions - changes the partition type from recovery to primary. After the format command, you need to do an additional command, "set id=27", to restore the partition type to recovery.
    I documented this in the post.
    This is why some people using the Microsoft instruction are still having problems. If you don't want to use Microsoft's work-around, fine, then don't. But do not insult people who are trying to share what they have found to work.
