KB5034441 update problem, error (0x80070643).
2024-01-10T15:18:19+00:00
I have tried to update and I get error 0x80070643 with update KB5034441. I have tried uninstalling the Windows update, restarting the Windows Uptade service, deleting the update files and I have also run the following commands:
DISM /Online /Cleanup-Image /CheckHealth
DISM /Online /Cleanup-Image /ScanHealth
DISM /Online /Cleanup-Image /RestoreHealth
DISM.exe /Online /Cleanup-Image /RestoreHealth /Source:C:RepairSourceWindows /LimitAccess
DISM /Online /cleanup-image /startcomponentcleanup
sfc /scannow
chkdsk C: /f
But nothing has fixed the problem
2024-01-11T18:16:15+00:00
The update KB5034441 failed with a fatal error when staging the WIM. This is due to a lack of free space in the WinRE partition. KB5034441: Windows Recovery Environment update for Windows 10, version 21H2 and 22H2: January 9, 2024 - Microsoft Support
Resizing the Recovery partition to 750 MB resolves the issue. That applies if you use the Windows-default winre.wim.
For OEM-supplied winre.wim (which has additional drivers and packages), ensure the Recovery partition's size is atleast 100 MB more than the size of the custom wim.
KB5028997: Instructions to manually resize your partition to install the WinRE update - Microsoft Support: https://support.microsoft.com/en-us/topic/kb5028997-instructions-to-manually-resize-your-partition-to-install-the-winre-update-400faa27-9343-461c-ada9-24c8229763bf
Note: The above MS article works only if your Recovery partition is situated next to (i.e., right side) the OS partition. You can check the disk layout by opening Disk Management.
(Based on what I've noticed on the forums, many users have decided to skip/hide the KB5034441 update and wait and see if Microsoft releases a fix.)
After command SFC /scannow
& resize of WinRE to 1GB, managed to get this update working. 👍
86 additional answers
    2024-01-18T15:37:38+00:00
    I went to disk mgt. and there are two partitions that may be the recovery partition - one has 1.68GB free and the other has 1.75GB free. I don't have the technical skill to delve any deeper than this into my PC. I am not sure that I have a real "recovery partition."
    2024-01-18T15:43:53+00:00
    Thanks Mondoshawan!
    A well written solution that's easy to follow. Worked great! Thanks again....
    Awesome! Glad I could help.
    2024-01-18T15:48:50+00:00
    If you use the free MiniTool Partition Wizard, as I describe in my solution, it clearly lists which of your partitions is the recovery partition, which is the boot partition, etc. Check it out: https://www.northshore-it.com/tips/how-tos/manually-resize-your-recovery-partition/
    2024-01-18T20:08:26+00:00
    I changed the size of the recovery partition to 1.2 g and the update still fails
