KB5034441 update problem, error (0x80070643).
2024-01-10T15:18:19+00:00
I have tried to update and I get error 0x80070643 with update KB5034441. I have tried uninstalling the Windows update, restarting the Windows Uptade service, deleting the update files and I have also run the following commands:
DISM /Online /Cleanup-Image /CheckHealth
DISM /Online /Cleanup-Image /ScanHealth
DISM /Online /Cleanup-Image /RestoreHealth
DISM.exe /Online /Cleanup-Image /RestoreHealth /Source:C:RepairSourceWindows /LimitAccess
DISM /Online /cleanup-image /startcomponentcleanup
sfc /scannow
chkdsk C: /f
But nothing has fixed the problem
2024-01-11T18:16:15+00:00
The update KB5034441 failed with a fatal error when staging the WIM. This is due to a lack of free space in the WinRE partition. KB5034441: Windows Recovery Environment update for Windows 10, version 21H2 and 22H2: January 9, 2024 - Microsoft Support
Resizing the Recovery partition to 750 MB resolves the issue. That applies if you use the Windows-default winre.wim.
For OEM-supplied winre.wim (which has additional drivers and packages), ensure the Recovery partition's size is atleast 100 MB more than the size of the custom wim.
KB5028997: Instructions to manually resize your partition to install the WinRE update - Microsoft Support: https://support.microsoft.com/en-us/topic/kb5028997-instructions-to-manually-resize-your-partition-to-install-the-winre-update-400faa27-9343-461c-ada9-24c8229763bf
Note: The above MS article works only if your Recovery partition is situated next to (i.e., right side) the OS partition. You can check the disk layout by opening Disk Management.
(Based on what I've noticed on the forums, many users have decided to skip/hide the KB5034441 update and wait and see if Microsoft releases a fix.)
After command SFC /scannow
& resize of WinRE to 1GB, managed to get this update working. 👍
86 additional answers
    2024-01-15T08:40:33+00:00
    John, that's strange. I am able to easily resize/move partitions with my Free Version of the MiniTool Partition Wizard (as I showed in my screenshots)
    I tried again, but every time I click "Apply", it pops up a screen asking me to pay. Perhaps I have the wrong "free" version :) Mine says "Demo".
    No worries though, I managed to use DiskPart, although I always get a bit nervous using that, and would definitely not recommend to anyone who's not done that sort of low-lever stuff before. I notice they seem to mix 0 and 1 based indices in that tool, which doesn't help...
    2024-01-15T11:31:55+00:00
    For those people who need to move partitions. You can boot your VMs or Notebooks/PCs from CD with an user friendly Linux distro ISO image (like Mint, choose your own) and move them with Gparted. It's a GUI tool. Very easy to use.
    2024-01-15T11:53:41+00:00
    So my choice is
    • trying to move some as immovable declared partitions which are placed in FAT between WinRE and c: in order to get some 500 MB extra to WinRE and of course nobody will be responsible if this fails
    • keep everything as it is, leaving known vulnerabilities on that machine
    • praying that microsoft publishes a bugfix to install their bugfix
    How careful is microsoft testing their updates. Putting it on one single machine and leaving for weekend ? Is microsoft honestly asking ppl to create a bootable linux distro to manipulate the FAT because they published a bugfix which can't be installed due to a bug?
    2024-01-15T13:48:05+00:00
    This article was not written for the average person. I do not understand where to go or what to do next.
