Device DISPLAY\ACR0628\5&591c33a&1&UID4356 was not migrated due to partial or ambiguous match.
2020-09-02T02:48:06+00:00
hi my problem is that i have a acer ed273, so 144hz and 120hz are fine but when i turn to 60hz my monitor turns to different colors, i have a laptop connected thru a HDMI and a 1060gtx.
Log Name:      Microsoft-Windows-Kernel-PnP/Configuration
Source:        Microsoft-Windows-Kernel-PnP
Date:          9/1/2020 9:02:15 PM
Event ID:      442
Task Category: None
Level:         Warning
Keywords:
User:          SYSTEM
Computer:      LAPTOP-9LRM6CAR
Description:
Last Device Instance Id: DISPLAY\Default_Monitor\1&8713bca&0&UID0
Class Guid: {4d36e96e-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FFFF0000F100
Present: false
Status: 0xC0000719
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9c205a39-1250-487d-abd7-e831c6290539}" />
    <EventID>442</EventID>
    <Version>0</Version>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x4000000000000000</Keywords>
    <TimeCreated SystemTime="2020-09-02T02:02:15.3165275Z" />
    <EventRecordID>982</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="296" />
    <Channel>Microsoft-Windows-Kernel-PnP/Configuration</Channel>
    <Computer>LAPTOP-9LRM6CAR</Computer>
    <Security UserID="S-1-5-18" />
  </System>
  <EventData>
    <Data Name="DeviceInstanceId">DISPLAY\ACR0628\5&591c33a&1&UID4356</Data>
    <Data Name="LastDeviceInstanceId">DISPLAY\Default_Monitor\1&8713bca&0&UID0</Data>
    <Data Name="ClassGuid">{4d36e96e-e325-11ce-bfc1-08002be10318}</Data>
    <Data Name="LocationPath">
    </Data>
    <Data Name="MigrationRank">0xf000ffff0000f100</Data>
    <Data Name="Present">false</Data>
    <Data Name="Status">0xc0000719</Data>
  </EventData>
</Event>
    2020-09-03T12:49:56+00:00
    ''Thanks you for updating to the latest version of windows 10''
    2020-09-03T13:02:59+00:00
    So for some reason there is an update trying to update and update but it cant so how to i delete that update?
    This is the update that is causing some trouble: 2020-08 Cumulative Update for Windows 10 Version 2004 for x64-based Systems (KB4566782)
    2020-09-03T18:50:40+00:00
    This is after running the Repair Install to update to Version 2004? Did that resolve your other problems?
    You can try manually installing the problem Update from here:
    https://www.catalog.update.microsoft.com/Search...
    Try the second download.
    If it fails then unless it's disrupting your use of the PC then I'd just wait for it to sort itself out. If it doesn't do so or is causing problems, then go through the steps again to repair Windows Update which may need to be refreshed.
    Keep me posted on your progress as I will be here to help until the case is resolved.
    2020-09-03T19:14:55+00:00
    Some updates were not installed.
    The following updates were not installed:
    Update to windows (KB4566782)
    2020-09-03T19:19:50+00:00
    Victor -
    This is after manually downloading and trying to install the update?
    If so then I said what to do next. You can either wait to see if it sorts itself out, or try again the steps that repair Windows Updates to see if one of them will do it.
