Device DISPLAY\ACR0628\5&591c33a&1&UID4356 was not migrated due to partial or ambiguous match.
2020-09-02T02:48:06+00:00
hi my problem is that i have a acer ed273, so 144hz and 120hz are fine but when i turn to 60hz my monitor turns to different colors, i have a laptop connected thru a HDMI and a 1060gtx.
Log Name:      Microsoft-Windows-Kernel-PnP/Configuration
Source:        Microsoft-Windows-Kernel-PnP
Date:          9/1/2020 9:02:15 PM
Event ID:      442
Task Category: None
Level:         Warning
Keywords:
User:          SYSTEM
Computer:      LAPTOP-9LRM6CAR
Description:
Last Device Instance Id: DISPLAY\Default_Monitor\1&8713bca&0&UID0
Class Guid: {4d36e96e-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FFFF0000F100
Present: false
Status: 0xC0000719
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9c205a39-1250-487d-abd7-e831c6290539}" />
    <EventID>442</EventID>
    <Version>0</Version>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x4000000000000000</Keywords>
    <TimeCreated SystemTime="2020-09-02T02:02:15.3165275Z" />
    <EventRecordID>982</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="296" />
    <Channel>Microsoft-Windows-Kernel-PnP/Configuration</Channel>
    <Computer>LAPTOP-9LRM6CAR</Computer>
    <Security UserID="S-1-5-18" />
  </System>
  <EventData>
    <Data Name="DeviceInstanceId">DISPLAY\ACR0628\5&591c33a&1&UID4356</Data>
    <Data Name="LastDeviceInstanceId">DISPLAY\Default_Monitor\1&8713bca&0&UID0</Data>
    <Data Name="ClassGuid">{4d36e96e-e325-11ce-bfc1-08002be10318}</Data>
    <Data Name="LocationPath">
    </Data>
    <Data Name="MigrationRank">0xf000ffff0000f100</Data>
    <Data Name="Present">false</Data>
    <Data Name="Status">0xc0000719</Data>
  </EventData>
</Event>
    2020-09-03T22:11:40+00:00
    I've asked you repeatedly if you did the Repair Install to Version 2004 because it was not made clear. If so then the files were reinstalled and should not be corrupted already unless something was done since then.
    You can run System File Checker from Step 10 in this checklist:
    http://answers.microsoft.com/en-us/windows/wiki... to check on the condition of the System Files.
