what does error code: 0x8019019a mean
2020-08-03T17:06:52+00:00
what does error code:  0x8019019a mean?
    2020-10-15T16:36:03+00:00
    I've got absolutely no tabs to use as you I do on excel or word. I can't check on any menu to bring down, and I have tried in settings to see, but nothing. I am on version Windows 10. I hope we can work it out, as the Outlook app always appears to be not user friendly.Anthony.
  2. Virginia M 41,995 Reputation points Independent Advisor
    2020-10-15T16:43:15+00:00
    Which version of Outlook are you using?
    Do you see the accountson the left-hand side?
    2020-10-15T17:12:42+00:00
    I'm using a Office Home & Student 2019 package that was added to my already apps with Windows 10, if that helps. No, I do not see accountson on the left-hand side, plus not sure what that is? Anthony
  4. Virginia M 41,995 Reputation points Independent Advisor
    2020-10-15T17:35:38+00:00
    Do you have a ‘File’ tab? If so click on this & choose account settings.
    If not then please provide a screenshot of what you see.
    Edit:
    It seems that version does not contain Outlook email client.
    Are you referring to Outlook.com which is webmail?
    2020-10-16T09:27:45+00:00
    No, I do not have ant file tab. When I got this computer in February only this year, Outlook app was already on my desktop with all the menus above with "Tools" etc., as my excel & word still have and use all the time. The others worked fine, but the outlook one kept saying I could not use until I activated that app. I tried everything to activate but could not, until it just turned into this, and you're right it changed into an outlook webmail and a browser which I never wanted. I've tried this morning restoring the app, but lost it, I've got it back as the webmail. Could you tell me how I can restore the original outlook back that came with the package, including Word/Excel/Powerpoint/OneNote & the Outlook, because it looks until I do, I can not fix the yahoo account. What I don't understand, it's been fine up to now fro August, when this app change finally took place as I se it. Sorry to go on, but I know you need all the facts, to be able to help me. Anthony
