How do you disable SearchApp.exe from running so that you can enable SLI in the Nvidia Control Panel?
2020-08-21T21:11:28+00:00
I'm unable to shut down SearchApp.exe in task manager so that I can enable SLI in the Nvidia control panel.  I've performed a clean boot and stopped the Windows Search service.
However as soon as I end task on  SearchApp.exe, it automatically restarts.  Because of this I'm unable to enable SLI in the Nvidia control panel.
SearchApp.exe is located in C:\Windows\SystemApps\Microsoft.Windows.Search_cw5n1h2txyewy
I'm unable to enable SLI if I boot into safe mode.  I already tried that.
When I had a version of Windows 10 pre version 2004, I had no problems ending task on everything running that prevented SLI from begin enabled.  I did a clean install of Windows 10 last night to fix a problem and now that the problem is fixed, I have a new one.  I really hope I don't have to install an older version of Windows 10 and upgrade to get around this problem.
Windows for home | Windows 10 | Cortana and search
2020-09-06T13:11:25+00:00
The previous answer is unlikely to work because Cortana keeps searchapp.exe running all the time (causing cpus to get hot).
The following commands worked for me. You have to paste them into in Administrator-level Command Prompt again and again until the timing is right and the "move" works.
cd %windir%\SystemApps
taskkill /f /im SearchApp.exe
move Microsoft.Windows.Search_cw5n1h2txyewy Microsoft.Windows.Search_cw5n1h2txyewy.old
Optional: to remove Cortana completely (in addition to stopping searchapp.exe), run the following command in Administrator-level Powershell:
Get-AppxPackage -allusers Microsoft.549981C3F5F10 | Remove-AppxPackage
David Spector
Springtime Software
67 additional answers
    2021-03-18T19:50:24+00:00
    That makes sense. Why didn't you say that in your answer to me? Have a nice day. And keep confusing people.
    2021-03-18T19:55:29+00:00
    Yes, Microsoft seems unable to design stuff right the first time, or recognize their mistakes afterward. So long as they are making profit on new hardware and devices, why should they waste time fixing bugs? Fixing bugs only makes customers happy with a company, and Microsoft doesn't care if they are disliked, since it apparently doesn't cut into their profits. Sorry to be so harsh, but it's the truth so far as I can see. I hope everyone discovers Everything, the free file search tool that works the way Microsoft can't do it: instantly.
    2021-04-08T21:58:13+00:00
    David
    thank you, I am 73 years old so not considered deft at fixing computer issues so please bear with me.
    How do I find the "Everything" file to fix the issue with searchapp.exe.
    Thanks in advance
    Jack Houston
    2021-04-08T23:40:24+00:00
    You are 73 years old and I am 74 years old, but we both can search the web. You can download Everything for free at https://www.voidtools.com/downloads/ .
    David
