How do you disable SearchApp.exe from running so that you can enable SLI in the Nvidia Control Panel?
2020-08-21T21:11:28+00:00
I'm unable to shut down SearchApp.exe in task manager so that I can enable SLI in the Nvidia control panel.  I've performed a clean boot and stopped the Windows Search service.
However as soon as I end task on  SearchApp.exe, it automatically restarts.  Because of this I'm unable to enable SLI in the Nvidia control panel.
SearchApp.exe is located in C:\Windows\SystemApps\Microsoft.Windows.Search_cw5n1h2txyewy
I'm unable to enable SLI if I boot into safe mode.  I already tried that.
When I had a version of Windows 10 pre version 2004, I had no problems ending task on everything running that prevented SLI from begin enabled.  I did a clean install of Windows 10 last night to fix a problem and now that the problem is fixed, I have a new one.  I really hope I don't have to install an older version of Windows 10 and upgrade to get around this problem.
Windows for home | Windows 10 | Cortana and search
2020-09-06T13:11:25+00:00
The previous answer is unlikely to work because Cortana keeps searchapp.exe running all the time (causing cpus to get hot).
The following commands worked for me. You have to paste them into in Administrator-level Command Prompt again and again until the timing is right and the "move" works.
cd %windir%\SystemApps
taskkill /f /im SearchApp.exe
move Microsoft.Windows.Search_cw5n1h2txyewy Microsoft.Windows.Search_cw5n1h2txyewy.old
Optional: to remove Cortana completely (in addition to stopping searchapp.exe), run the following command in Administrator-level Powershell:
Get-AppxPackage -allusers Microsoft.549981C3F5F10 | Remove-AppxPackage
David Spector
Springtime Software
67 additional answers
  1. Deleted
  2. Deleted
    2021-09-23T18:52:59+00:00
    Hi, so i recently fixed the problem that you were struggling with(and I for a while). When you tried Davids cmd, I did that too. It removed the searchapp. If the search app is removed, you can't enable or disable search because none of those things will work if there's no search.
    Solution: 1
    press Win+R
    type cmd and press Ctrl+Shift+Enter
    It should be in the administrator cmd prompt.
    Type sfc /scannow
    wait till its done and once it is, check if it says Windows Resource Protection found corrupted files and successfully repaired them. If it does, exit out of cmd prompt and see if search works.
    Solution 2
    If it does not work, try going into task manager and services. Then open services scroll down to windows search and click enabled if its disabled already.
    Solution 3
    If that does not work try to rebuild the search index by going into indexing options and pressing the button called rebuild.
    Once its done rebuilding, your problem should be fixed.
    Solution 4
    If that does not work, I would suggest to restore windows 10 to a previous point.
    Right click the search bar and open task manager. Then click file and run a new task. Type Control Panel and press enter. Go to recovery and click open system restore. Click next, and choose a date that you want to restore to. Then, the next is pretty self-explanatory. Your PC will start to rebuild to match up to the restore date. It may take a few hours or if you don't have many applications or if your PC is new, it will finish in a couple of minutes. You can step away from your computer because it will restart when its done by itself. After system restore is done, try to log in. If it works then its a success! Sorry if my English is bad. If you can't understand something clearly just reply.
  4. Deleted
