How do you disable SearchApp.exe from running so that you can enable SLI in the Nvidia Control Panel?
2020-08-21T21:11:28+00:00
I'm unable to shut down SearchApp.exe in task manager so that I can enable SLI in the Nvidia control panel.  I've performed a clean boot and stopped the Windows Search service.
However as soon as I end task on  SearchApp.exe, it automatically restarts.  Because of this I'm unable to enable SLI in the Nvidia control panel.
SearchApp.exe is located in C:\Windows\SystemApps\Microsoft.Windows.Search_cw5n1h2txyewy
I'm unable to enable SLI if I boot into safe mode.  I already tried that.
When I had a version of Windows 10 pre version 2004, I had no problems ending task on everything running that prevented SLI from begin enabled.  I did a clean install of Windows 10 last night to fix a problem and now that the problem is fixed, I have a new one.  I really hope I don't have to install an older version of Windows 10 and upgrade to get around this problem.
Windows for home | Windows 10 | Cortana and search
2020-09-06T13:11:25+00:00
The previous answer is unlikely to work because Cortana keeps searchapp.exe running all the time (causing cpus to get hot).
The following commands worked for me. You have to paste them into in Administrator-level Command Prompt again and again until the timing is right and the "move" works.
cd %windir%\SystemApps
taskkill /f /im SearchApp.exe
move Microsoft.Windows.Search_cw5n1h2txyewy Microsoft.Windows.Search_cw5n1h2txyewy.old
Optional: to remove Cortana completely (in addition to stopping searchapp.exe), run the following command in Administrator-level Powershell:
Get-AppxPackage -allusers Microsoft.549981C3F5F10 | Remove-AppxPackage
David Spector
Springtime Software
67 additional answers
    2021-05-19T09:34:08+00:00
    David Spector
    Springtime Software
    Hi David I deleted searchapp.exe but I want to use my search box. How can I reload searchapp.exe ? Please help me
    2021-05-19T10:25:00+00:00
    As discussed in depth above, the free software called Everything is a wonderful search program that will catalog your entire disk in a few seconds then provide instant access to all your files by partial name. Unlike the Windows builtin Cortana/Searching, it will not load your cpu or increase disk accesses to anywhere near the same amount.
    This is my last posting here on this subject, so I hope that people who are searching for a solution to their overheating CPU (thanks to Microsoft) will read this entire thread.
    2021-05-19T14:20:10+00:00
    Hi David sorry to bother you and thanks for your answering but I still want to use the original software windows. I don't care health of CPU. Can you teach me how can I reload searchapp.exe.
    2021-06-06T15:50:54+00:00
    hello sir i tried your stuff and copy paste commands in cmd after that my pc is getting restarted after every few minutes idk please help me , how to undo that commands ? please! help
