How do you disable SearchApp.exe from running so that you can enable SLI in the Nvidia Control Panel?
2020-08-21T21:11:28+00:00
I'm unable to shut down SearchApp.exe in task manager so that I can enable SLI in the Nvidia control panel.  I've performed a clean boot and stopped the Windows Search service.
However as soon as I end task on  SearchApp.exe, it automatically restarts.  Because of this I'm unable to enable SLI in the Nvidia control panel.
SearchApp.exe is located in C:\Windows\SystemApps\Microsoft.Windows.Search_cw5n1h2txyewy
I'm unable to enable SLI if I boot into safe mode.  I already tried that.
When I had a version of Windows 10 pre version 2004, I had no problems ending task on everything running that prevented SLI from begin enabled.  I did a clean install of Windows 10 last night to fix a problem and now that the problem is fixed, I have a new one.  I really hope I don't have to install an older version of Windows 10 and upgrade to get around this problem.
Windows for home | Windows 10 | Cortana and search
2020-09-06T13:11:25+00:00
The previous answer is unlikely to work because Cortana keeps searchapp.exe running all the time (causing cpus to get hot).
The following commands worked for me. You have to paste them into in Administrator-level Command Prompt again and again until the timing is right and the "move" works.
cd %windir%\SystemApps
taskkill /f /im SearchApp.exe
move Microsoft.Windows.Search_cw5n1h2txyewy Microsoft.Windows.Search_cw5n1h2txyewy.old
Optional: to remove Cortana completely (in addition to stopping searchapp.exe), run the following command in Administrator-level Powershell:
Get-AppxPackage -allusers Microsoft.549981C3F5F10 | Remove-AppxPackage
David Spector
Springtime Software
67 additional answers
    2021-04-09T12:48:01+00:00
    David
    Thank you for getting back to me so quick. There are six options to download; is one better than the other.
    Thanks again
    Jack
    2021-04-09T13:37:09+00:00
    Probably most will work. If your Windows is 32 bit, you can't use the 64 bit executable. These kind of choices are not specific to Everything, so you should search the Web to learn what they mean and which will work best on your computer. Any advice I give to you might not work for someone else.
    2021-05-06T13:27:06+00:00
    sir i used your command in admin powershell and it worked succesfully. but now i want to restore the usability of search again so can you kindly tell me the command of undoing it.
    2021-05-06T15:03:31+00:00
    The question of restoring searching has been answered above. However, I strongly recommend Search Everything, a freeware tool, as it will not cause your CPU to overheat and have a shorter lifespan.
