my pc keep crashing tried many solution nothing worked im still getting black screen/BSOD
2020-09-22T00:47:20+00:00
hello
(before i say anything what u will read right here is the same on a thread i posted before and im doing new post bcs my problem didnt got fixed)
my pc is  still new a year and half now
but for a long time im getting alot BSOD
tried to  fix the issues  with many methodds nothing works i even opened one thread here about the problem and nothing worked for me
and the thing  that its happening to me its soo weird im having the weirdest PC ever
here is whats going on
so i login  to my pc doing work playing games watching youtube etc...
everything fine then BOOM all of sudden my pc crashes and restart by its on
and then everything is fine im it didnt crash anymore
and then i restart my pc  or close it for different reason and then  when i use it everything is fine  then BOOM bsod and its restart and everything is fine after
and also sometimes when i get bsod
there  a precentge to collect information about the crash
sometimes it went 100% and restart everything is fine
but sometimes its stays at 0% and then it restart BUT guess what happen i get black screen this msg i forgot what it said exactly but its something like this ( pls reboot insert a proper boot device ) something like that
but when i reboot by ctrl + alt + del to restart im having the same msg. so what i did i just turn off my pc by
the boot button wait couple of min then boot again and everything is fine again  i login i go do my work THEN BOOM  my pc crashes and restart by its own then it wont crash again incouple of days if i didnt close my pc
so  what i mean by all of this is
when my pc restart by it own there will be no another crashes for couple  of says then it will crash
but when i restart or close my pc annd open it  by my self and then the crashes happen again  until it restart on its own to work fine
and so what i do i just open my pc wait for it to crash and restart by its own and so i work fine without crashes and when im done i keep my pc open so i  dont have to open it by myself and crash all over again
and thats happen to me for long time i was battling with this ****
i just dont know  **** is going on
tried alot of **** nothing works
sry for the long msg
(and   i posted a thread like this before it in here
https://answers.microsoft.com/en-us/windows/forum/all/my-pc-keep-crashing-and-im-getting-alot-of-bsod/eb936ddf-4bec-4476-bb8d-aecf286a107c
or check it on my profile)
and i have gtx 1660ti
i5 9600k
16g ram
ADATA ssd
WDC
    2020-09-27T22:40:36+00:00
    i did download everything on that site u gave me from asrock
    but im still getting crashes
    the crash goes like this:
    im working everything is ok then all of sudden my pc restart on its on but first what happend in a split second i get black screen
    its like my monitor got unpluged u know what i mean then its restart
    but its not restart like my windows tell me thats its restarting no
    its kick me out back to the bios when i see my motherboard company
    2020-09-27T22:50:16+00:00
    Did you install all of the latest drviers from your motherboard downloads page including the VGA driver here:
    http://www.asrock.com/MB/Intel/Z390%20Pro4/inde... ?
    What is the Display driver version and date presently installed in the Device Manager?
    2020-09-27T22:56:55+00:00
    i told previosly i cant install VGA i get this msg
    im pretty sure my gpu is updated
    2020-09-27T23:12:36+00:00
    The driver you showed you tried to install yesterday was Intel Graphics. But the driver you're showing is installed now is Nvidia.
    The installed driver is very recent, do you know how it was installed? Compare it to the one the Nvidia Driver updater finds:
    http://www.nvidia.com/Download/Scan.aspx?lang=e...
    To troubleshoot the Bluescreen error, download, install and run BluescreenView from NirSoft here: https://www.nirsoft.net/utils/blue_screen_view.... which should pinpoint the faulting driver or software.
    Report back the reported cause for further steps to fix it.
    2020-09-27T23:23:44+00:00
    i install the update myself
    just to give u heads up the crashes was happening after and before the updates*
    every update invidia make wont fix my problem for some reason
    and now i downloded the bluescreeenview what do i do now
