how do i locate the full model number?
i tried to and i got the serial number and the product name which is Z390 Pro4
hello
(before i say anything what u will read right here is the same on a thread i posted before and im doing new post bcs my problem didnt got fixed)
my pc is still new a year and half now
but for a long time im getting alot BSOD
tried to fix the issues with many methodds nothing works i even opened one thread here about the problem and nothing worked for me
and the thing that its happening to me its soo weird im having the weirdest PC ever
here is whats going on
so i login to my pc doing work playing games watching youtube etc...
everything fine then BOOM all of sudden my pc crashes and restart by its on
and then everything is fine im it didnt crash anymore
and then i restart my pc or close it for different reason and then when i use it everything is fine then BOOM bsod and its restart and everything is fine after
and also sometimes when i get bsod
there a precentge to collect information about the crash
sometimes it went 100% and restart everything is fine
but sometimes its stays at 0% and then it restart BUT guess what happen i get black screen this msg i forgot what it said exactly but its something like this ( pls reboot insert a proper boot device ) something like that
but when i reboot by ctrl + alt + del to restart im having the same msg. so what i did i just turn off my pc by
the boot button wait couple of min then boot again and everything is fine again i login i go do my work THEN BOOM my pc crashes and restart by its own then it wont crash again incouple of days if i didnt close my pc
so what i mean by all of this is
when my pc restart by it own there will be no another crashes for couple of says then it will crash
but when i restart or close my pc annd open it by my self and then the crashes happen again until it restart on its own to work fine
and so what i do i just open my pc wait for it to crash and restart by its own and so i work fine without crashes and when im done i keep my pc open so i dont have to open it by myself and crash all over again
and thats happen to me for long time i was battling with this ****
i just dont know **** is going on
tried alot of **** nothing works
sry for the long msg
(and i posted a thread like this before it in here
or check it on my profile)
and i have gtx 1660ti
i5 9600k
16g ram
ADATA ssd
WDC
Latest drivers here http://www.asrock.com/MB/Intel/Z390%20Pro4/inde...
Latest BIOS here: http://www.asrock.com/MB/Intel/Z390%20Pro4/inde...
But it says that if your PC is running OK there is no need to upgrade BIOS. So if you do decide to upgrade be sure to follow the steps closely
holy bananas
this is scary i hate getting involved in the bios ****
my pc is not running normally
like i said above
is it still safe?
It is safe as long as you follow the instructions provided. If you are in doubt you can contact your AsRock Support to have them walk you through it.
For BIOS Update there are normally instructions on the Downloads page and also sometimes in a Read Me file included in the downloaded file.
apologies greg i was busy
anyway i came to ask you about the lastest drivers link
there is alot of option to download which one to choose
and i came to notify you about couple of things it might help
before i used to check the reliability history after every crash and i used to get " hardware error "
but some of the advisors told me to put this command chkdsk C: /f /r /x
its worked for couple of days but the problem came back but the different is that there is no " hardware error "
right now im having difficulty bcs im getting a consistent BSOD with an error " critcal process died "
it stuck as 0% then the pc restart and i get this msg "reboot and select proper boot device or insert boot media in selected boot device and press a key "
when i press cltr+ alt + del to restart from this i have the same msg
but when i shut down my pc and open it its gone until i get bsod again
