my pc keep crashing tried many solution nothing worked im still getting black screen/BSOD
2020-09-22T00:47:20+00:00
hello
(before i say anything what u will read right here is the same on a thread i posted before and im doing new post bcs my problem didnt got fixed)
my pc is  still new a year and half now
but for a long time im getting alot BSOD
tried to  fix the issues  with many methodds nothing works i even opened one thread here about the problem and nothing worked for me
and the thing  that its happening to me its soo weird im having the weirdest PC ever
here is whats going on
so i login  to my pc doing work playing games watching youtube etc...
everything fine then BOOM all of sudden my pc crashes and restart by its on
and then everything is fine im it didnt crash anymore
and then i restart my pc  or close it for different reason and then  when i use it everything is fine  then BOOM bsod and its restart and everything is fine after
and also sometimes when i get bsod
there  a precentge to collect information about the crash
sometimes it went 100% and restart everything is fine
but sometimes its stays at 0% and then it restart BUT guess what happen i get black screen this msg i forgot what it said exactly but its something like this ( pls reboot insert a proper boot device ) something like that
but when i reboot by ctrl + alt + del to restart im having the same msg. so what i did i just turn off my pc by
the boot button wait couple of min then boot again and everything is fine again  i login i go do my work THEN BOOM  my pc crashes and restart by its own then it wont crash again incouple of days if i didnt close my pc
so  what i mean by all of this is
when my pc restart by it own there will be no another crashes for couple  of says then it will crash
but when i restart or close my pc annd open it  by my self and then the crashes happen again  until it restart on its own to work fine
and so what i do i just open my pc wait for it to crash and restart by its own and so i work fine without crashes and when im done i keep my pc open so i  dont have to open it by myself and crash all over again
and thats happen to me for long time i was battling with this ****
i just dont know  **** is going on
tried alot of **** nothing works
sry for the long msg
(and   i posted a thread like this before it in here
https://answers.microsoft.com/en-us/windows/forum/all/my-pc-keep-crashing-and-im-getting-alot-of-bsod/eb936ddf-4bec-4476-bb8d-aecf286a107c
or check it on my profile)
and i have gtx 1660ti
i5 9600k
16g ram
ADATA ssd
WDC
    2020-10-07T11:16:35+00:00
    (1) In Reliability History...
    (a) Click the "View technical details" button for the crash event,
         or double-click the event itself to get there.
    (b) Copy the details to the Clipboard with the button on bottom.
    (c) Post it to us.
    (2) Can you find it mentioned in "right-click START, Event Viewer"? Then post that as well.
    Hopefully, we can BING around for a possible cure with that information.
    2020-10-07T18:01:21+00:00
    Source
    Windows
    Summary
    Hardware error
    Date
    ‎10/‎5/‎2020 11:47 PM
    Status
    Report sent
    Description
    A problem with your hardware caused Windows to stop working correctly.
    Problem signature
    Problem Event Name: LiveKernelEvent
    Code: 141
    Parameter 1: ffff8808bbc02050
    Parameter 2: fffff8042584a998
    Parameter 3: 0
    Parameter 4: 2130
    OS version: 10_0_19041
    Service Pack: 0_0
    Product: 768_1
    OS Version: 10.0.19041.2.0.0.768.101
    Locale ID: 1033
    Extra information about the problem
    Bucket ID: BAD_DUMPFILE
    thats the hardware error that i got
    im not saying any right click thing
    and btw this report doesnt have the "View technical details"
    like the other report beside it
    2020-10-07T23:13:34+00:00
    (1) Since you've done everything you can with driver updates, it is time to believe it is a hardware issue. Here is an article with a few easy things to try...
    https://softwaretested.com/windows/what-is-the-livekernelevent-code-141/#:~:text=In%20most%20cases%2C%20the%20LiveKernelEvent%20Code%3A%20141%20is,a%20clean%20and%20updated%20copy%20of%20the%20software.
    What is the LiveKernelEvent Code: 141 and How to Deal With It?
    Note: The article appears to make sense, but I know nothing (bad or good) about any downloads or links that are there (or anywhere else). And one of them sounds suspicious.
    Fixes 3 & 4 look easy, but, of course, your computer must have the BIOS capability. If you are overclocked, maybe just set it to default clocking first instead of rushing to underclocking it.
    (2) I didn't see hardware tests offered at your computer's site. Maybe check in BIOS to see whether you've got them there. Or proceed to Greg's steps 4 & 5 on page one. The stress test sounds interesting.
    (3) Here are other threads on the topic...
    https://answers.microsoft.com/en-us/windows/forum/windows_10-performance/problem-event-name-livekernelevent-code-141/a8242bc9-9241-4f7a-87c2-8b29eb56d932
    Problem Event Name: LiveKernelEvent Code: 141
    https://answers.microsoft.com/en-us/windows/forum/windows_10-performance/live-kernel-event-141/4abf3c3b-4be8-4a64-8f16-94875241f40f
    Live Kernel Event 141
    Too bad it wasn't a thing software could cure. If an easy hardware fix doesn't get it, I think you are in for it.
    2020-10-08T00:02:11+00:00
    hello
    i forgot to tell ya about  the livekernelcode
    like i said before  i was getting hardware error then it disappeared bcs if i remember correctly i did the a run check disk and the hardware error went away and now it came back
    anyway
    do u suggeest me to avoid the the link for safety tho?
    edit:
    looking more in the first link
    i did all of these except for those that required me to go to the  bios/UFEI
    since i became really stress using them  yikes i just dont like it to go in the bios
    since this is a hardware issue is in mainly something within the gpu itself
    do  ineed to remove at the end or something
    2020-10-08T00:24:23+00:00
    You've got to go into BIOS & look. If it seems complex, just report back what you see. The ESC key probably exits BIOS without saving any changes, but surely there will be a legend showing what your key for that is if different.
    But -- if you can easily make the changes -- then look for a key that will save changes & exit.
    If you've never been in BIOS (to change anything), then likely "reset to defaults" will also likely set things right. There should be a button for that at the BIOS exit screen. Then save changes before you exit. It could be a high-tech game found a way to "maximize" settings in there unbeknownst to you.
    So long as you don't click any links or take any downloads at a suspicious site, you're probably fine. And I also trust Windows Defender to do its best anyhow.
