What is the Motherboard full model number?
Put it in here to get your drivers:
hello
(before i say anything what u will read right here is the same on a thread i posted before and im doing new post bcs my problem didnt got fixed)
my pc is still new a year and half now
but for a long time im getting alot BSOD
tried to fix the issues with many methodds nothing works i even opened one thread here about the problem and nothing worked for me
and the thing that its happening to me its soo weird im having the weirdest PC ever
here is whats going on
so i login to my pc doing work playing games watching youtube etc...
everything fine then BOOM all of sudden my pc crashes and restart by its on
and then everything is fine im it didnt crash anymore
and then i restart my pc or close it for different reason and then when i use it everything is fine then BOOM bsod and its restart and everything is fine after
and also sometimes when i get bsod
there a precentge to collect information about the crash
sometimes it went 100% and restart everything is fine
but sometimes its stays at 0% and then it restart BUT guess what happen i get black screen this msg i forgot what it said exactly but its something like this ( pls reboot insert a proper boot device ) something like that
but when i reboot by ctrl + alt + del to restart im having the same msg. so what i did i just turn off my pc by
the boot button wait couple of min then boot again and everything is fine again i login i go do my work THEN BOOM my pc crashes and restart by its own then it wont crash again incouple of days if i didnt close my pc
so what i mean by all of this is
when my pc restart by it own there will be no another crashes for couple of says then it will crash
but when i restart or close my pc annd open it by my self and then the crashes happen again until it restart on its own to work fine
and so what i do i just open my pc wait for it to crash and restart by its own and so i work fine without crashes and when im done i keep my pc open so i dont have to open it by myself and crash all over again
and thats happen to me for long time i was battling with this ****
i just dont know **** is going on
tried alot of **** nothing works
sry for the long msg
(and i posted a thread like this before it in here
or check it on my profile)
and i have gtx 1660ti
i5 9600k
16g ram
ADATA ssd
WDC
im sorry greg but im struggling here
my motherboard is from ASRock i went to their website to check the lastest update but i got lost there was alot of things.
and how do i check my motherboard version?
The step is to determine if you have the latest UEFI firmware from the PC or motherboard maker's Support Downloads web page. Go there now to see what the latest available BIOS/UEFI update is.
Then compare it with the one you presently have installed. To find this out you can check in System Information under BIOS Version.
Then make sure all other drivers are up to date.
hello Greg
my drivers were updated before all of my nvidia drivers are up to date
but i cant follow the first step on the BIOS/UEFI firmware i cant seems to understand it hope u clarify more
Hi CB. II'm Greg, an installation specialist, 10 years awarded Windows MVP, and Volunteer Moderator, here to help you.
Then type System Information in Start Search, compare the latest BIOS/UEFI firmware version with the one showing in System Information, and install it following closely the instructions on the download page, and on any Read Me file included in download.
Updating drivers from the Device Manager or Windows Update is rarely enough. The most basic thing we need to learn to maintain a PC is keep the latest manufacturer's drivers installed from their Support Downloads web page.
Start with Step 4 to turn off Startup freeloaders which can conflict and cause issues, then Step 7 to check for infection the most thorough way, then step 10 to check for damaged System Files, and also Step 17 to test a new Local Admin account. Then if necessary continue with the other steps to go over your install most thoroughly.
https://www.wepc.com/how-to/stress-test-cpu-ram/
https://www.tenforums.com/tutorials/16474-prime...
https://www.lifewire.com/free-hard-drive-testin...
https://mashtips.com/ssd-health-test-and-perfor...
HP and Dell have hardware diagnostics triggered by tapping the ESC or F12 keys respectively as you power on.
Best is to use the HDD/SSD manufacturer's own if there is one, otherwise use Seatools bootable long test: http://blog.nowherelan.com/2013/04/04/boot-seat...
Follow this up with a full Disk Check from the Command Prompt in Repair Mode or from bootable media: https://www.groovypost.com/howto/check-hard-dri... if necessary from the Command Prompt at boot: https://www.tenforums.com/tutorials/2294-advanc...
Report back the reported cause for further steps to fix it.
I hope this helps. Feel free to ask back any questions and keep me posted. If you'll wait to rate whether my post resolved your problem, I will keep working with you until it's resolved.
______________________________________________
