Hi all,
I had the same problem with my AORUS B550 MASTER motherboard - After it went into sleep mode the Bluetooth could not be re-activated again, unless I did full power down and unplug as described in the previous comments.
I changed my windows settings and it solved the problem.
I'm using Windows 10 Pro 20H2 and firmware F11p for the motherboard.
Go to Settings, go to Power & Sleep section.
Click on Additional Power Settings under Related settings.
On your current Preferred plans click on Change plan settings.
Click on Change advanced power settings.
I changed a number of settings here so i'm not sure exactly which one it was, but I suspected it was one of the following:
- Wireless Adapter Settings - Changed to Maximum performance
- USB settings - Changed to disabled
Hope this helps everyone!
**EDIT:**Actually the above steps didn't work. The Bluetooth still stops after waking up from sleep mode.
I looked into it further and other people have said it was actually an issue with the Realtek 2.5G LAN chip and this issue also effects other motherboards using this chip as well.
The following fix has been OK for me, but haven't tried it for long periods of sleep mode yet.
Go to Device Manager , Network adapters, Realtek Gaming 2.5GbE Family Controller.
Right click on Propertie s **,**go to Advanced tab and change the following settings:
Disable all the following settings:
-Advanced EEEE
-Energy-Efficient Ethernet
-Gigabit Lite
-Green Ethernet
-Power Saving Mode
Credit to matthys70:
