Flight simulator please insert disc???
2020-08-18T04:23:28+00:00
When I start up the game it tells me to press any button to start. I press a button and then it tells me to insert the disk and press continue. I don't have a disk because I purchased the premium Deluxe Edition online it's bought-and-paid-for it says the game is installed but everytime I press continue it just pops up again please insert disc.
    2021-01-21T22:56:20+00:00
    Hi there I'm having the exact same problem, bought the premium deluxe edition with digital copy. Installs in seconds which should take hours with the size of the game. Game starts then always says insert discs ????
    I've tried to uninstall and reinstall this same issues?
    Are you still have same issues this morning
    This worked for me. I put in a FSX disk and when the popup window came up I just clicked on "continue" The program took right off.
    2021-01-21T23:59:15+00:00
    I just had this happen to me. Did some quick digging around on it.
    I closed the app. Opened the Microsoft store app and clicked on "Downloads and Updates" from the "three dots" menu and did all of the updates.
    NOTE: NONE of the updates had anything to do with MSFS 2020.
    After doing the updates though, I restarted the game and it started normally.
    2021-01-24T02:14:49+00:00
    Never had this problem on Xbox I have this problem on PS4 yesterday trying to play GTA v with my cousins and then it says insert disc when I bought it online so I don't know
    2021-01-27T01:38:41+00:00
    Make sure you are logged into your MS account, this worked for me and no longer got the insert cd message.  Hope this helps...
    CoolHand
    2021-01-27T15:52:19+00:00
    I have put the iso file in dropbox.
    This is the link:
    https://www.dropbox.com/t/mvIWwqjvGwV1fFHi
    Put the iso file where you want. Open it (double click) before starting FS.
    You must see something like this in explorer: Dvd-station(G:) MFS DISK 1
    Open flight simulator.
    That's it.
    Please let me know if it solved the problem.
    I cant get into the file anymore, can you share it again?
