Flight simulator please insert disc???
2020-08-18T04:23:28+00:00
When I start up the game it tells me to press any button to start. I press a button and then it tells me to insert the disk and press continue. I don't have a disk because I purchased the premium Deluxe Edition online it's bought-and-paid-for it says the game is installed but everytime I press continue it just pops up again please insert disc.
    2020-10-17T17:08:20+00:00
    I have Bitdefender and there I turned off the "firewall" and it suddenly worked.
    Hi!
    I had the same problems with Bitdefender, the firewall didn't allow it to go online, so I contacted Bitdefender's support, and they gave me this solution to fix the problem:
    To troubleshoot the encountered situation, please follow these steps:
    -open Bitdefender
    -click Protection
    -click Settings under Firewall
    -click Settings again
    -set the Default Application Behaviour to Allow
    -set the Network Adapters to Home/Office.
    Thank you thank you thank you!!!! This solved my problem after two and a half months of failures!!!!!
    2020-10-17T18:48:21+00:00
    I wonder if it is a good idea securitywise to allow traffic for all programs in firewall? I wish Bitdefender could provide better solution.
    2020-10-17T19:59:38+00:00
    I don‘t think it is a good idea to switch off the Bitdefender firewall completely. It would be better to only exclude the MS FS app from being checked by the firewall.
    I am using Kaspersky Internet security; there you have the option to exclude individual apps from being blocked. Maybe the same can be done in Bitdefender.
    2020-10-19T10:46:50+00:00
    I figured out something if you have it installed with XBOX Game Pass for PC as I do, you need to set your Xbox account as your STORE account It was saying that I didn't have the game pass but I did hope this helps!
    2020-10-19T10:58:48+00:00
    I bought from steam and so many problems still
