Thanks mate, awesome :)
Flight Simulator 2020 PC code edition is asking for start DVD despite of digital owner installed
I ordered and installed the FS 2020 version with the PC code.
After FS 2020 I installed the digital owner add-on (can be only installed afterwards).
But when I start the FS 2020 then a screen is appearing to ask for a disk that I don't have.
What can I do to get it started?
* Mod note on January 11, 2021:
This thread is being locked. Please read through the thread for info on:
* Why the ISO can't be sent to you and is not available on a file transfer website
* Disabling Bitdefender
* Creating your own ISO from the disk
2020-08-30T20:47:37+00:00 -
2020-08-31T20:02:23+00:00 Gie, could you send the ISO to juanlusapinto_at_hotmail.com? Though I own the digital standard version of the game since launch day, I have not been able to play due to the dreaded "insert disc" error. Thank you so much in advance!
2020-08-31T23:51:02+00:00 Hi Gie, please could you send the ISO to **email removed for privacy**?
I've owned the digital deluxe version of msfs 2020 from the beginning but suddenly for no known reason today the "insert disc" error appeared. I have spent 6 hours trying all the fixes over an over without any luck and it would happen today when I got a decent hotas (hopefully)!!! Thank you for your support Gie, Graham.
2020-09-01T08:18:02+00:00 Hi, I found a workround was to disable Bitdefender Firewall, but not a satisfactory solution for security reasons. Would therefore appreciate the ISO to ******@btinternet.com. Thanks, Lionel
Deleted
