Fix: Your Device is Missing Important Security and Quality Fixes. Error (0x80080005)
2020-05-21T20:55:46+00:00
here were some problems installing updates, but we'll try again later. If you keep seeing this and want to search the web or contact support for information, this may help: (0x80080005).
This is the error I get every time for a few days.
I tried troubleshooting but it didn't work.
Many have said in other queries(for the same problem) to Reset SoftwareDistribution & Catroot2 folders. But I'm scared to do that because I'm worried if something happens to my laptop.
Please suggest a way to solve this issue.
Below attached is the screenshot of the issue.
Kindly help,
Thank you.
2021-08-20T11:26:59+00:00
This is a frequent issue sometimes caused by driver compatibility errors: Windows 10 Update Assistant (microsoft.com)
You could try downloading the Windows Update Assistant. It can help bump your version of windows past this sort of update error to the latest version.
Choose the 1st option for the update assistant: Download Windows 10 (microsoft.com)
70 additional answers
  1. Sumit 44,416 Reputation points Volunteer Moderator
    2021-06-17T13:15:02+00:00
    Hi, John
    Tried your fix listed above but could not get past "net stop msiserver"
    I closed the admin cmd window.
    Still getting this message: Your device is missing important security and quality fixes.
    Machine keeps restarting. What should I try now?
    Janet
    *** Email address is removed for privacy ***
    Janet, let us sort this issue.
    Right-click Start>Run.
    Type in msinfo32 and press enter.
    Take a screenshot of the System Summary window and post it in the next reply.
    2021-06-17T13:36:46+00:00
    Thanks John, here is Screenshot
  3. Sumit 44,416 Reputation points Volunteer Moderator
    2021-06-18T08:35:21+00:00
    (Sumit asked for a screenshot, not John).
    Please update BIOS to ver 318 from 317 and try again.
    X556UA - Support (asus.com)
    2021-06-22T11:51:55+00:00
    Sorry Sumit, thanks for the advice.
