Fix: Your Device is Missing Important Security and Quality Fixes. Error (0x80080005)
2020-05-21T20:55:46+00:00
here were some problems installing updates, but we'll try again later. If you keep seeing this and want to search the web or contact support for information, this may help: (0x80080005).
This is the error I get every time for a few days.
I tried troubleshooting but it didn't work.
Many have said in other queries(for the same problem) to Reset SoftwareDistribution & Catroot2 folders. But I'm scared to do that because I'm worried if something happens to my laptop.
Please suggest a way to solve this issue.
Below attached is the screenshot of the issue.
Kindly help,
Thank you.
2021-08-20T11:26:59+00:00
This is a frequent issue sometimes caused by driver compatibility errors: Windows 10 Update Assistant (microsoft.com)
You could try downloading the Windows Update Assistant. It can help bump your version of windows past this sort of update error to the latest version.
Choose the 1st option for the update assistant: Download Windows 10 (microsoft.com)
70 additional answers
    2020-10-18T11:18:29+00:00
    hello john dev I tried this steps twice but it didn't solve the problem please suggest something else to solve the problem thanks
    Rohit Kumar.
    2020-11-21T08:20:09+00:00
    this action does solve the problem
    2020-12-24T14:25:29+00:00
    SHOULD WE  DO THESE STEPS AFTER IT RECOMMENDS A RETRY?
    2021-02-10T19:54:09+00:00
    ren %systemroot%\system32\catroot2 catroot2.bak
    Acess is denied.
