Fix: Your Device is Missing Important Security and Quality Fixes. Error (0x80080005)
2020-05-21T20:55:46+00:00
here were some problems installing updates, but we'll try again later. If you keep seeing this and want to search the web or contact support for information, this may help: (0x80080005).
This is the error I get every time for a few days.
I tried troubleshooting but it didn't work.
Many have said in other queries(for the same problem) to Reset SoftwareDistribution & Catroot2 folders. But I'm scared to do that because I'm worried if something happens to my laptop.
Please suggest a way to solve this issue.
Below attached is the screenshot of the issue.
Kindly help,
Thank you.
2021-08-20T11:26:59+00:00
This is a frequent issue sometimes caused by driver compatibility errors: Windows 10 Update Assistant (microsoft.com)
You could try downloading the Windows Update Assistant. It can help bump your version of windows past this sort of update error to the latest version.
Choose the 1st option for the update assistant: Download Windows 10 (microsoft.com)
70 additional answers
    2021-08-13T12:29:29+00:00
    Make sure when you go to start cmd, you right click it and choose "Run as Administrator". Just in case you missed that, because not running as admin will give the access denied error.
    2021-08-20T02:12:07+00:00
    2021-08-24T09:36:39+00:00
    I'm having this issue also. And my wireless card is acting flaky also. This happened last year also. When the update finally did install last year the card worked perfectly.
    Now, I'm getting the error about missing security and quality fixes. What is missing? And why are so many independent groups other than microsoft explaining how to fix this issue.
    My machine is up to date for all anti-virus security related features and is reporting no issues, so how do I fix this?
    Also, this is a forum, and forums for such things are great for chatting about such things, but where are the online official Microsoft recipes for troubleshooting such issues. The only fixes I'm finding in step-by-step form are by independent groups.
