I had done essentially the same thing with my PC, which is also a new HP computer, but this did not solve the problem. Here's more history:
I first started and setup the PC on 4/1/20, and disabled use of McAfee software. I did not have any problems with the machine until 5/8/20, when it started having Kmode exceptions which became so frequent that Windows said I had to reset the PC's Windows
installation. I tried a partial reset that kept my data files, but the PC still had the Kmode exceptions, so I did a complete reset of the PC on 5/8/20. I again removed McAfee software, and continued using the PC. The PC ran without problems until 5/18/20,
when it starting having Kmode exceptions again. The Kmode exceptions again became so frequent that Windows said I needed to reset the PC.
So, I reset the PC on 5/19/20 and again removed McAfee software from the control panel. I discovered that I could cause the Kmode exceptions to happen at will, just by trying to perform a Windows system update, after Windows had installed all the above updates
that I described in my initial post yesterday.
I think others may have the same problem. You can easily test it, by trying to perform a Windows system update using the following menus and selections:
control panel
system and security
security and maintenance
maintenance
start maintenance
I suspect that after Windows installs KB4052623, it then has a problem trying to install KB2267602 that causes a Kmode exception. This might happen for other PC's, whenever they get to a point in their update cycle that causes them to try these updates.
The latest version of KB4052623 was released on 4/30/20, about a week before my PC started having Kmode exception crashes.
Phil
