pc has been running fine since we last spoke. 10 mins ago pc randomly restarted and i have lots of errors / 1 critical in event viewer.
93 of these: the CMDre number changes on each one
The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\00000088
CMDre 00000003 00001568 00000000 00000003 00000000
The message resource is present but the message was not found in the message table
error2 : ID 28, kernel-event tracing
Error setting traits on Provider {8444a4fb-d8d3-4f38-84f8-89960a1ef12f}. Error: 0xC0000001
error 3: event 1000
Faulting application name: iCUE.exe, version: 3.28.75.0, time stamp: 0x5ec58f18
Faulting module name: Qt5Core.dll, version: 5.13.1.0, time stamp: 0x5d6a32fb
Exception code: 0xc0000005
Fault offset: 0x000311de
Faulting process ID: 0x2ba0
Faulting application start time: 0x01d6418f78528db6
Faulting application path: C:\Program Files (x86)\Corsair\CORSAIR iCUE Software\iCUE.exe
Faulting module path: C:\Program Files (x86)\Corsair\CORSAIR iCUE Software\Qt5Core.dll
Report ID: ae099828-478c-433d-9ba7-f54d22fe6bc9
Faulting package full name:
Faulting package-relative application ID:
error 4: bug check 1001
The computer has rebooted from a bugcheck. The bugcheck was: 0x00000116 (0xffffa78e587a3010, 0xfffff80027512888, 0xffffffffc000009a, 0x0000000000000004). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 1b6f0bda-3dac-4c24-9a54-fda2516cccef.
error 5: 6008 ID
The previous system shutdown at 15:07:34 on 13/06/2020 was unexpected.
critical error: event 41 kernel power
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
- <Event xmlns="**http://schemas.microsoft.com/win/2004/08/events/event**">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>8</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2020-06-13T14:32:04.0615194Z" />
<EventRecordID>7620</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-KA4BF7B</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">278</Data>
<Data Name="BugcheckParameter1">0xffffa78e587a3010</Data>
<Data Name="BugcheckParameter2">0xfffff80027512888</Data>
<Data Name="BugcheckParameter3">0xffffffffc000009a</Data>
<Data Name="BugcheckParameter4">0x4</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
</EventData>
</Event>
