That will not be possible as I am browsing in private mode, so there is no history, besides with all the sites I tried I would have a hard time finding it even with a history.
But actually I think the Antvirus upgrade made the diffenrence in the end.
Help Fix event 642 [SOLVED]
Catalog Database (4288,D,12) Catalog Database: The database format feature version 9080 (0x2378) could not be used due to the current database format 1568.20.0, controlled by the parameter 0x410022D8 (8920 | JET_efvAllowHigherPersistedFormat).
Microsoft Windows [Version 10.0.19041.264]
DISM and sfc scan commands are all successful.
Any help on this please?
EDIT: February 2nd 2021
New update kb4598291 and kb4598299 solved this issue!
2021-02-04T09:09:56+00:00
